air water sediment three phase flow
Old   November 5, 2012, 16:41
Default air water sediment three phase flow
matteo
gionrambo is on a distinguished road
I am trying to model a coastal engineering problem, and maybe Fluent is not very suitable for this kind of issue.
There is a pile-breakwater on wich are acting both regular and irregular waves. Id like to track the air-water interface (I know that the most suitable model is the multiphase VOF model) and at the same time to track bed sediment motion around piles.
Im quite sure that for the bed sediment the Euler model can be used.
You know that only one multiphase model can be chosen, thus I dont know if I should create two different models, the first to investigate the air-water interface and the second to check the sediment transport.
What do you think about this solution?
Or maybe someone knows if the usage of the mentioned models (VOF and Euler) for a three phase flow (air-water-sediment) is possible.
Any help or advice is appreciate.
Mat.
gionrambo is offline   Reply With Quote
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 05:21
Solving 3 phase flow cfdfresher FLUENT 0 January 10, 2012 05:47
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 05:44
Air-water flow (VoF). Need help :( Luke1984 FLUENT 6 October 19, 2009 09:59
Water jet in confined hot air cross flow Jim Clancy FLUENT 0 November 24, 2007 16:14
