Convergence issue on Solar chimney simulation
Prev Previous Post   Next Post Next
Old   November 19, 2012, 17:00
Default Convergence issue on Solar chimney simulation
Mani.juve is on a distinguished road
Hello Every body
I'm modeling a solar chimney power plant by Fluent . I use fluent to solve The Steady-state problem . my Bcs are pressure inlet (=0) and Pressure outlet ( =0 ) and use S2S radiation model to simulate . I see that the residuals don't converge . I have changed urf of Energy to 0.5 , doesn't help ; momentum to 0.2 ; doesn't help and dissipation rate to 0.5 ; doesn't help . the residuals of velocity are under 10^-3 energy about 10^-5 epsilon about 10^-3 and k between 10-3 and 10-4 . I am monitoring my Velocity on a special plane and see that it fluctuates between 11.1 and 11.7 . for my problem , the order ( 1.1 * 10^1 m/s ) is rational and sufficient but I'm not sure is the solution reliable ? I've used k-e RNG model ( becuase I think Re number is Low , and RNG responses better . is it right ? )
Mani.juve is offline   Reply With Quote
[Commercial meshers] meshing a 3D solar chimney kasool OpenFOAM Meshing & Mesh Conversion 0 November 27, 2010 12:24
convergence issue Rohit Kumar Batra CFX 1 March 27, 2008 17:43
convergence for an Unsteady simulation Palani Velladurai FLUENT 1 March 19, 2007 10:56
Convergence issue Omer CFX 2 March 7, 2007 10:37
CFX-Solver, issue with convergence behavior Andy CFX 7 September 5, 2006 03:24
