Sloshing using VOF at High Loads
Old   November 29, 2012, 05:17
Default Sloshing using VOF at High Loads
Odakkattuvalasu
rsslnt is on a distinguished road
Dear Community,
Please offer help if you have exposure to simulating sloshing process at high pressure gradients.
I have a fuel tank with 100 psi pressure inside. I have to simulate the sloshing during the loading of 11g downward and 7g horizontal.I have provided acceleration in the operating conditions. Two questions are there:
1. Solution diverging even with small time step (0.0005)
2. Should I provide 100 psi in operating condition and initialize with 100 psi.
I think solution diverging due to adverse pressure gradient due to the high acceleration. How to overcome this problem?
Thank you,
rss
rsslnt is offline   Reply With Quote
Old   November 29, 2012, 12:13
Elias Paez
sicfred is on a distinguished road
I don't think the pressure is the problem.
Did you check the courant number? did you use the variable time step? maybe you should decrease, even more the time step.
Any way, 11g and 7g are VERY high loads, are they constant or time-depend?
I'm curius, under what conditions do you have these loads?
sicfred is offline   Reply With Quote
sloshing, vof model
VOF or not for sloshing of a full tank? Brian FLUENT 3 August 17, 2011 06:35
Using VOF for sloshing air-water boiling system Dibakar Rakshit FLUENT 0 March 12, 2008 07:40
VOF Sloshing - beating pattern in force output? Brian FLUENT 0 May 18, 2006 10:59
HELP.......sloshing problem using VOF suryakant FLUENT 3 August 11, 2005 13:32
Multicomponent fluid Andrea CFX 2 October 11, 2004 05:12
