LES convergence problem in ANSYS/FLUENT 14.0
Old   December 4, 2012, 04:36
Default LES convergence problem in ANSYS/FLUENT 14.0
Ebrahim
Ebrahim is on a distinguished road
Dear all,
I want to solve flow field in a complex geometry(respiratory system) Using LES method. I used an LRN k-epsilon converged solution as an initialization for LES. the pressure-velocity coupling is PISO algorithm and the 2nd order implicit method was used for discritizing unsteadiness. however, the solution diverged at the first time step after about 50 iterations. I'm using ANSYS/FLUENT 14.0. I have solved the flow field by fluent 6.3.26 without any problem but since I must include inlet perturbation for my pressure-inlet boundary condition and FLUENT 6.3.26 doesn't have inlet perturbation for pressure-inlet condition, I should use ANSYS/FLUENT 14.0. Does anybody know why ANSYS/FLUENT 14.0 cannot give a converged solution while FLUENT 6.3.26 can do so?
Moreover can you help me in solving my problem?
helps will be appreciated.
Regards,
Ebrahim
Ebrahim is offline   Reply With Quote
convergence, les
Convergence problem suthichock Main CFD Forum 27 May 11, 2009 07:05
3D Fluid Flow Convergence problem Emily FLUENT 2 March 21, 2007 22:18
LES convergence problem: Ning FLUENT 2 March 14, 2007 21:08
CONVERGENCE PROBLEM - oil boiler MM FLUENT 1 February 15, 2007 05:24
convergence problem with SIMPLER NURAY KAYAKOL Main CFD Forum 1 February 24, 1999 13:43
