VOF model: Make extra inlet for air in the tank?
Like Tree1Likes
  • 1 Post By cfd seeker
Old   January 11, 2013, 06:44
Default VOF model: Make extra inlet for air in the tank?
Blue's Avatar
Blue is on a distinguished road
I am analyzing a tank by Fluent VOF model, which has one inlet at the top and three outlets at bottom. Initially half tank is filled with water and half volume by air (lower half volume has been patched for water). I have taken transient, impilcit scheme for solution+ Modified HRIC. The inlet flow rate of water has been taken as half of steady state flow rate i.e., water level of tank will go down as time will advance. This will create less space of water in tank and air will have more volume to occupy.
My questions:
(a) Do I have to make another inlet in the tank for air? Or Will air expand itself inside tank?
(b) Is this a open channel problem?
Blue is offline   Reply With Quote
Old   January 11, 2013, 06:52
cfd seeker is on a distinguished road
No you don't have to make an extra inlet for air, air will expand by itself as water level decreases under gravity
No. This is Multiphase problem with air and water as two phases. Read the details of the VOF model in Fluent's theory guide
Blue likes this.
cfd seeker is offline   Reply With Quote
Old   January 11, 2013, 06:56
Blue's Avatar
Thank you cfd seeker
fluent, tank, vof model
VOF Inlet condition Rizwan FLUENT 15 July 5, 2018 16:33
Weld surface deformation by VOF model minhaj_iut FLUENT 5 February 26, 2017 23:51
What outlet BC to use for a numerical wave tank with a velocity inlet? JamesJ FLUENT 1 August 8, 2012 17:43
Heterogeneous reaction between phases with VOF model sooroo3 Fluent UDF and Scheme Programming 0 February 15, 2011 02:59
help needed for vof model yan FLUENT 3 December 16, 2005 01:17
