Fire & Smoke in Building
Old   September 11, 2003, 14:48
Default Fire & Smoke in Building
Jenn
I would like to simulate the development of fire(temperature distribution) and smoke in a building by using Fluent in order to validate the fire safety system. Unfortunately, I can't find any function in Fluent to simulate fire and smoke. Can anyone tell me if there is any function to do this in Fluent and what are they ?
It looks like I could simply put a (constant) heat source and (constant) smoke source without any chemical reaction to simulate fire (temperature distribution) and smoke, and treat them as passive scalars except I need to include the thermal stratification in the model. Could you please give me any suggestion or comment on this ?
Thanks a million.
Cheers
Old   September 12, 2003, 09:09
Default Re: Fire & Smoke in Building
walter
you can write UDFs which supply time-varying heat sources and time-varying species sources to represent the energy and smoke released from a fire.
Old   December 17, 2012, 13:11
Default Fire & Smoke simulation
eeh
eeh is on a distinguished road
Hi all,
Can anyone provide a tutorial for smoke and fire simulation using ANSYS Fluent?
Please urgent reply
eeh is offline   Reply With Quote
Old   December 18, 2012, 02:14
SSL
msaeedsadeghi is on a distinguished road
Fire is combustion, Smoke is soot, CO2, ...
Fluent can model these so you can model Fire and Smoke using fluent. So easy.
msaeedsadeghi is offline   Reply With Quote
Old   December 29, 2012, 12:04
eeh
Thank u msaeedsadeghi, but i'm a new user of ANSYS fluent;
Is there any tutorials that can help?
Regards
Old   December 29, 2012, 23:15
SSL
See tutorials about combustion in these addresses.
https://www.sharcnet.ca/Software/Flu...g/main_pre.htm
http://jullio.pe.kr/fluent6.1/help/html/tg/main_pre.htm
http://202.118.250.111:8080/fluent/F...g/main_pre.htm
http://cdlab2.fluid.tuwien.ac.at/LEH...g/main_pre.htm
[foam-extend.org] Error compiling OpenFOAM-1.6-ext Canesin OpenFOAM Installation 137 January 20, 2016 14:56
Car park ventilation and impulse fans guillaume Phoenics 9 October 27, 2015 05:57
Compilation error OF1.5-dev on Suse10.3 darenyang OpenFOAM Installation 0 April 29, 2009 04:55
smoke (fire simulation) matt Phoenics 4 October 23, 2007 01:40
smoke (fire simulation) matt Fidelity CFD 0 January 5, 2007 04:47
