March 18, 2014, 03:41 |
Problem with compiling UDF in Fluent
Nusselt
Rep Power: 12 |
I tried to compile UDF file by using Fluent but this message appeared: 'nmake' is not recognized as an internal or external command, operable program or batch file. What does this mean? Can someone help to solve this? Appreciate your help. |
March 21, 2014, 07:38 |
anbu
Rep Power: 12 |
hi nusselt,
check your setup environment is enabled in the fluent launcher tab for udf compilation. try to compile the program in the same os i.e; program and fluent should be in same 64-bit or 32-bit. when your compiling change the default libudf name and give a try, before giving build and load. if these settings are not working, try to launch your fluent by using command. */press/* windows key and R */type in run commands/* CMD */type in cmd/* cd\ */copy and paste below line/* \Fluent.Inc\ntbin\fluent 3ddp -t8. try this Last edited by wyldckat; March 21, 2014 at 16:24. Reason: 4 posts, 2 minutes apart each one |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) | Yogini | Fluent UDF and Scheme Programming | 7 | October 3, 2012 07:24 |
my problem wuth UDF compiling | m.beh | FLUENT | 3 | November 22, 2011 00:47 |
UDF compiling problem in Flient 6.3 | jeevan kumar | FLUENT | 2 | February 25, 2009 00:43 |
fluent UDF external library lapack problem | Rick | FLUENT | 0 | May 7, 2008 10:16 |
