cfd fluent simulation of heatpipe
Like Tree1Likes
  • 1 Post By msaeedsadeghi
Old   January 23, 2013, 18:33
Exclamation cfd fluent simulation of heatpipe
rajesh reddy
rajesh_3114042@yahoo.com is on a distinguished road
hi i am unable to simulate the heat pipe in fluent which has two phase flow is it required to give pressure outlet also for multi phase i am unable to use the porous zone too
rajesh_3114042@yahoo.com is offline   Reply With Quote
Old   January 24, 2013, 03:47
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
So what exactly is your question?
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   January 24, 2013, 06:56
SSL
msaeedsadeghi is on a distinguished road
There is no need of using multiphase in heatpipe modeling
majid2015 likes this.
msaeedsadeghi is offline   Reply With Quote
Old   July 23, 2013, 17:48
Mohammad Bahreini
mecman is on a distinguished road
hi all
i want simulate heat pipe with fluent,any body know how simulate this case in fluent?i know i must use VOF model for this,but i cant simulate boiling in pipe...
pls help regard
mecman is offline   Reply With Quote
Old   October 17, 2013, 02:56
Default multiphase flow -superheated steam
Muthu
mari009 is on a distinguished road
Hii Everyone...
I am using multi-phase mixture model.. my fluid are superheated steam(as a primary phase) and water-liquid (as a secondary phase). The problem was property of steam(enthalpy) wat i need supposed to get is not getting
(for e.g) In my boundry condition enthalpy value of a steam from a steam table is h=3000kj/kg but wat i am getting from cfd results is nearly h=1200kj/kg...
how to fix the problem ...
mari009 is offline   Reply With Quote
Old   April 28, 2015, 05:43
Default Heat Pipe Simulation in Fluent
k.vedprakash is on a distinguished road
Hello guys,
i am trying to design a heat pipe in ansys fluent.
temperatures at evaporator and condensor are 50degree and 25 degree respectively.
liquid fillinf ratio is 70%.
so here are the conditions i gave in my simulation.
i chose double precision, transient pressure based solver.
model- multiphase-volume of fluid with energy equation on.
In phase interaction - mass - number of transfer mechanisms - 1
Evaporation-condensation with both 0.1 frequency
and saturation temperature of 320K.
Surface tension of 0.072 n\m with wall Adhesion.
Boundary Conditions - Evaporator as Pressure inlet
Guage pressure: 0
Initial Guage Pressure: 0
Temp: 350K
Condensor as Pressure outlet
Guage pressure: 0
Back flow temperature: 0
Adiabatic as Wall
No slip wall
contact Angle: 70
I am not getting any proper result with these conditions. Rest all are kept default values.
Please Anyone of you guys are familiar with the design, it would be great if you could help me
k.vedprakash is offline   Reply With Quote
Old   November 7, 2015, 14:07
Default help
majid
majid2015 is on a distinguished road
hello msaeedsadeghi
i am simulating heat pipe with one phase, i have problem in simulating porous wick,the capillary driven flow, can you help?
best regards
majid2015 is offline   Reply With Quote
CFD Design...The CFD Future John C. Chien Main CFD Forum 20 November 19, 2015 23:40
Fluent CFD vs Fluent CFX gpan FLUENT 0 December 21, 2011 13:09
[ICEM] Export unstructured periodic mesh from ICEM CFD to Fluent ivanddd ANSYS Meshing & Geometry 1 February 3, 2011 00:51
Where do we go from here? CFD in 2001 John C. Chien Main CFD Forum 36 January 24, 2001 21:10
PC vs. Workstation Tim Franke Main CFD Forum 5 September 29, 1999 15:01
