Modeling a rotating vertical axis stream turbine |
February 11, 2013, 13:03 |
Richard Smith
Rep Power: 13 |
Hi guys, new to the forum and after digging around to find answers to my problems i am yet to find a definite answer, so i make a thread
I'm doing my 3rd year dissertation on modeling a Vertical Axis Tidal Turbine (VATT) in FLUENT. What i am looking at is the efficiency drop/rise when more blades are added to the arrangement (Darrieus style VATT) for example 3 airfoils compared to 4,5,6 etc. Now i have my solidworks model of a simplified VATT imported into ANSYS Workbench, then placed inside a cylinder and the the cylinder inside a larger control volume. The model is meshed appropriately and set up using a sliding mesh arrangement with the cylinder 'fluid' volume rotating at a set angular velocity hence turning the turbine. My many questions lie in the running solutions, obviously to model the turbine rotating over time i have to use a transient method. questions: 1) Do i first have to run a steady state solution to convergence and then proceed to a transient model (with say 50 iterations per time step?) 2) Do i record lift, drag, and moment coefficients of the turbine as a whole? and in what axes? Thank you for your time, if you need anymore information or pictures i can provide them. Thanks again Richard |
Water turbine CFD modeling | Peter | Main CFD Forum | 7 | April 4, 2016 02:31 |
State of the Art in CFD for wind turbine modeling | SET_WIND | Main CFD Forum | 0 | October 9, 2012 06:01 |
vertical axis wind turbine: Steady State? Chart? | Jbc | ANSYS | 0 | September 5, 2012 17:34 |
Vertical axis wind turbine in NUMECA | ArslanOZCAN | Fidelity CFD | 2 | July 21, 2011 05:04 |
rotating domain in rotating domain, different axis | Robert Stringer | CFX | 3 | December 4, 2006 07:04 |
