Limitation of Global Courant Number (VOF Model)
Like Tree8Likes
  • 8 Post By vig
Old   February 14, 2013, 04:34
Default Limitation of Global Courant Number (VOF Model)
Blue's Avatar
Blue is on a distinguished road
The default value of Global Courant Number is given 2 in Ansys Fluent, But how much this value can be changed? What is optimum value? What will be impact on results by increasing and decreasing this value? I am modeling a tank drainage problem and monitoring the interface.
Thank you
Blue is offline   Reply With Quote
Old   February 15, 2013, 05:35
vig
anonymous
vig is on a distinguished road
Global Courant number could be experimented in the range of 1-5.
Ideally, Interface should not cross more than 1 cells in 1 time step, which is stability criterion for explicit scheme. In that way, optimal value should always be lesser than or equal to 1.
However, other equations should not be affected by the time restriction imposed on the volume fraction tracking. Fluent internally breaks the actual time step into sub-time steps, so that each sub-time step satisfies the Courant based criterion.
There is another entry for Courant number on the multiphase panel, by default 0.25.
Therefore the number of internal sub-time steps = Global Courant number devided by Local Courant number
For Global Courant Number = 2, sub-time-steps = 8
rsaha, FarzinD, BlnPhoenix and 5 others like this.
vig is offline   Reply With Quote
cfl, fluent, global courant number, tank emptying, vof
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 04:13
alphaEqn.H in twoPhaseEulerFoam cheng1988sjtu OpenFOAM Bugs 15 May 1, 2016 16:12
Problem with FloatingObject Leech OpenFOAM Running, Solving & CFD 10 March 29, 2012 15:24
directMapped problem panda60 OpenFOAM Bugs 4 July 8, 2010 10:23
Global courant number what mean erica FLUENT 0 November 24, 2007 05:41
