Centrifugal Pump
Old   March 20, 2015, 02:21
Default Centrifugal Pump
SUBODH KHULLAR
sk692 is on a distinguished road
Hi there
I am simulating flow in a centrifugal pump using MRF in fluent. But I am getting almost constant or rather increasing total head with increase in flow rate at constant RPM. However with increase in speed the total head increases i.e. I am getting a almost constant value at a particular speed irrespective of the flow rate.
I have tried all the BC combinations, I can think off. I have tried
- mass flow inlet and pressure outlet
- mass flow inlet and outflow
- pressure inlet ad pressure outlet
But the results are coming the same.
Can anyone shed some light on this problem.
Thanks a lot in advance.
sk692 is offline   Reply With Quote
Old   March 31, 2016, 06:17
Default Centrifugal pump
mady
madhu is on a distinguished road
I have not used fluent as of now but have some good experience in CFX for centrifugal pump simulation
check below parameters.
Boundary condition:
Inlet : Total Pressure (Atmospheric)
Outlet : Mass flow rate (kg/sec)
Domains
Rotating domain ( Impeller fluid region)
Stationary domain ( Casing)
Interface
Rotating to stationary with GGI connection with Frozen rotor interface
Check the direction of rotation and rotational axis of impeller.
These data may help u to cross check
thanks with Regards,
Madhu
madhu is offline   Reply With Quote
centrifugal pump Chalghoum CFX 18 April 16, 2014 06:37
Autoblade centrifugal pump template mahdi balali Fidelity CFD 3 February 18, 2014 08:56
centrifugal Pump Efficiency A.farid Main CFD Forum 0 March 31, 2012 07:39
Centrifugal Pump Cavitation problem or not. ismael.s CFX 13 February 27, 2012 08:00
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 03:20
