Continuity does not converge, but mass balance is ok!
Old   November 28, 2013, 05:26
Default Continuity does not converge, but mass balance is ok!
Andrea
Andrea1984 is on a distinguished road
Hi guys,
I'm running a steady state simulation of a gas turbine combustor with species transport model (the fluids are methane and air at the moment).
I am in the very first stage of the modeling so I am trying to reach a good solution for the "cold" field (i.e. without activating the reactions at all); my problem is that the scaled residuals of continuity got stuck at about 5e-2 and I am not able to enhance this value in any way ( I am using "coupled" for pressure-velocity coupling and I have tried to play with URFs, set all the discretization schemes at first order upwind, tried the pseudo-transient formulation).
However all the other variables are converged, the mass imbalance is very low and the contours of pressure, temperature, velocity etc seems quite reasonable.
The value of the mass imbalance variable are between -4e-7 and 3e-7 in the whole domain.
Do you think I can trust this results even if the continuity equation is not converged? It may be that the scaled residuals are not a good way to evaluate the continuity convergence in this case?
Thank you
Andrea
Andrea1984 is offline   Reply With Quote
DPM mass balance help jpinho FLUENT 1 April 25, 2014 06:48
AMI interDyMFoam for mixer nu problem danny123 OpenFOAM Programming & Development 8 September 6, 2013 02:34
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 09:34
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 10:44
DEFINE_SOURCE, injection in one Cell, mass balance Vitali FLUENT 2 April 27, 2007 16:39
