Importing surface/profile for data writing in Fluent
Old   February 25, 2013, 14:13
Default Importing surface/profile for data writing in Fluent
Daniel
fadiga is on a distinguished road
Hi all.
I have a series of calculations which need to be done on a model geometry, with slightly varying interal dimensions. However there are locations in this geometry which are constant and which I need to extract the data from. I need to run the simulation in transient so I need to define these "lines" during pre-post in order to write and export the data per time step. Since I have to do quite a few, it would be nice to be able to write the coordinates file once, and then just import it each time....
Do you know of any way to import "surfaces" (as per the Fluent definition of a surface) which you can then use to define the locations of the data you need to write?
I tried already to create and read "profiles", with just coordinates but then I cannot the select the profile under surfaces when I try to write the data.
(i attached snapshot of the relevant command window i refer to)
Thanks for your help!
fadiga is offline   Reply With Quote
Old   July 10, 2014, 12:52
Sreeraj Varma
sreerajvarma is on a distinguished road
Hi
I am also facing the same problem. I jist want to import transient data for the whole simulation at a few locations like wall.Could anyone help? I require this because otherwise the data will be too large and i will not be able to store\process it
Thank you
sreerajvarma is offline   Reply With Quote
Old   July 11, 2014, 13:25
Sreeraj Varma
Originally Posted by sreerajvarma View Post
Hi
Thank you
Hi
I'm just a beginner in Fluent Udf and want to simulate a shock tube. But since I do not have space to store the large amount of data generated from the solution I would like to save data at just a few particular locations. For this I wrote the UDF given below.
#include "udf.h"
DEFINE_INIT(sree_shock_tube_init,d)
cell_t c;
Thread *t;
float xc[ND_ND];
thread_loop_c(t,d)
begin_c_loop_all(c,t)
C_CENTROID(xc,c,t);
if (xc[0] < 3.2 )
C_U(c,t) = 0.;
C_V(c,t) = 0.;
C_P(c,t) = 2026500.0;
C_T(c,t) = 300.0;
C_R(c,t) = 23.536;
else
C_U(c,t) = 0.;
C_V(c,t) = 0.;
C_P(c,t) = 10132.5;
C_T(c,t) = 300.0;
C_R(c,t) = 0.11768;
end_c_loop_all(c,t)
DEFINE_RW_FILE(writer,fp)
face_t f;
Domain *d;
Thread *t;
float fc[ND_ND];
double pres,tem,vel,vels,mach;
thread_loop_f(t,d)
begin_f_loop_all(f,t)
F_CENTROID(fc,f,t);
if( fc[0]==0 || fc[0]==3.2 || fc[0]==6.4 || fc[0]==9.6 )
pres=F_P(f,t);
tem=F_T(f,t);
vel=F_U(f,t);
vels=pow(1.4*287.002*tem,0.5);
mach=vel/vels;
fprintf(fp,"%f: %f: %f: %f",pres,tem,vel,mach);
end_f_loop_all(f,t)
But when I interpret this code in fluent I get parse error on line no: 54 and 71. Could anyone tell why this error comes. I am just a beginner in Fluent and also doesn't have much experience in handling C
Best Regards
Old   July 11, 2014, 14:05
Sreeraj Varma
I removed the parse errors and the udf is interpreting fine.But when I try to run the above UDF in ansys Fluent and calculate I receive the following error message:
Error: Received fatal signal (segmentation fault). and it closes automatically
I guess it must be problem in the udf coding. I also hooked the function in both write cas and data initially and later tried hooking only to write data file alone. I want to save the pressure , temperture velocity and mach no: at a few locations alone and later use them in cfd post.
Could anyone suggest a solution to this problem
Old   July 12, 2014, 01:23
Sreeraj Varma
When I try to run the above UDF in ansys Fluent and calculate I receive the following error message:
export, fluent, import, profile
How to Mix AIR and WATER Elvis1991 FLUENT 12 December 1, 2016 12:28
UDF in FLUENT for importing csv files Boo Fluent UDF and Scheme Programming 0 July 13, 2011 22:22
importing .stl file to Fluent snudurupati FLUENT 0 July 15, 2009 11:21
importing unmeshed surface from gambit to fluent NISHIKANT TAMRAKAR FLUENT 1 March 7, 2009 14:08
Importing a structured mesh into Fluent Flav FLUENT 0 November 30, 1999 10:57
