Help Plotting Function vs. Position in Fluent
Old   March 19, 2013, 12:46
Default Help Plotting Function vs. Position in Fluent
Andre Joubert
AJoubert is on a distinguished road
Hi everyone, I'm new to these forums and came here to see if I could get any help solving a small problem I have with creating a plot in Fluent.
I am simulating the flow through a converging nozzle and need to plot a function of mass flow rate versus pressure ratio (m_dot vs. p1/p2) along the length of the nozzle in order to verify my calculated value for critical back pressure agrees with the value determined by the simulation. My question is how exactly should I go about this? I have been trying to read through the help documentation but cannot seem to find the answer. The closest I came was by looking at defining a custom field function but I could not manage to figure out how to piece together the desired function based on the available menu items.
If anyone could give me any guidance on how to create this plot I would greatly appreciate it!
AJoubert is offline   Reply With Quote
foamToTecplot360 thomasduerr OpenFOAM Post-Processing 121 June 11, 2021 10:05
pushback function for vectors in Fluent UDFs ScottN Fluent UDF and Scheme Programming 0 January 31, 2011 09:20
DPM UDF particle position using the macro P_POS(p)[i] dm2747 FLUENT 0 April 17, 2009 01:29
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 20:50
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
