March 22, 2013, 06:21 |
Solution Initialization
I'm a new user of Fluent... In a steady simulation should the solution be independent of the initial conditions? I mean... depending on the solution initialization parameters a get different results... is that bad? Regards. |
March 22, 2013, 07:45 |
OJ
Rep Power: 20 |
Bad initialization should result in longer convergence periods, but the results shouldn't be too different for different initializations, provided the boundary conditions and other settings remain the same.
OJ |
March 22, 2013, 09:28 |
Alex
Rep Power: 47 |
fluent 14, solution initialization |
UDF - Error while Solution Initialization | QuocHung_Phan | Fluent UDF and Scheme Programming | 2 | October 11, 2013 03:03 |
Why 3D solid-pore geometry showing diverged solution? | Sargam05 | OpenFOAM | 0 | December 3, 2012 15:45 |
Using fmg initialization with solution steering from journal | Costoich | FLUENT | 0 | April 20, 2011 14:19 |
Conduct initialization with a old mesh solution | Jianfeng Zou | FLUENT | 1 | September 12, 2007 06:06 |
Discussion about Mesh independant solution | Seb | Main CFD Forum | 13 | May 22, 2001 13:37 |
