Problem with 2D ICEM mesh check in fluent
Like Tree1Likes
  • 1 Post By Rameche Candane
Old   October 5, 2007, 05:19
Default Problem with 2D ICEM mesh check in fluent
Nicola
Hello everyone! I created a 2D mesh in ICEM but when I import it in fluent 6 I have a warning during check mesh: "mesh has negative volumes!" What's the problem? If someone can help me I thank him very much.
Old   October 5, 2007, 08:55
Default Re: Problem with 2D ICEM mesh check in fluent
Greg
It's not a problem of Fluent. It means that your meshing is not good, try to decrease the size of your cells. For 2D meshing I use Gambit but It's the same problem, size of cells too big for your geometry.
Old   October 11, 2007, 03:55
Rameche Candane
The size of cells are too small and not too big. Coarsen the mesh near the wall but take care u dont coarsen it too much - for the gradients are quite significant near the wall. Are else create the geometry by specifying the dimensions in mm in ICEMCFD. (its like mentioning for 1mm specify 1000mm or 100cms) try importing it to Fluent and then set the scale in fluent and then do the analysis.
Regards, Rameche
Usman15 likes this.
Old   March 25, 2013, 05:56
Question simulation's probleme on fluent
khe
khe is on a distinguished road
hello everyone,
i I created a 2D mesh in GAMBIT but when I import it in fluent 6.0 I have a problem: i can't check it ! ! !
the "check"icon isn't accessible
What's the problem?
khe is offline   Reply With Quote
[ICEM] Unstructure Meshing Around Imported Plot3D Structured Mesh ICEM kawamatt2 ANSYS Meshing & Geometry 17 December 20, 2011 11:45
[snappyHexMesh] snappyHexMesh won't work - zeros everywhere! sc298 OpenFOAM Meshing & Mesh Conversion 2 March 27, 2011 21:11
[ICEM] Meshing problem from ICEM CFD to Fluent cfdonlinederafa ANSYS Meshing & Geometry 2 September 21, 2010 16:16
Importing ICEM mesh to Fluent mr_stoked FLUENT 1 June 25, 2010 03:24
prob while exporting icem cfd hexa mesh to fluent mani CFX 4 March 7, 2007 03:41
