April 30, 2013, 01:36 |
how to select particular surface using tui?
Johnson Emmanuel
Rep Power: 16 |
when i use fluent in windows machine the following command works fine. /display/set/contours/surfaces <required plane name> () but when i tried same in linux machine it throws following error: Error: GENERAL-CAR-CDR: invalid argument [1]: improper list Error Object: #f Kindly help how to write in linux.( I feel "()" makes this error) |
journal, tui |
[ICEM] Problems with coedge curves and surfaces | tommymoose | ANSYS Meshing & Geometry | 6 | December 1, 2020 11:12 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 02:09 |
solid edge problem....can you help? | cindy | Main CFD Forum | 3 | April 5, 2004 13:43 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 10:56 |
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin | Kaushik | FLUENT | 1 | May 8, 2000 06:47 |
