Oscillating of Interface in VOF method
Old   April 14, 2013, 03:12
Default Oscillating of Interface in VOF method
amir mofakham
amir.mofakham is on a distinguished road
Hi
I want to use fluent to simulate the motion of a slug through a 2D channel.
I used
-explicit VOF method
-pressure-velocity Coupling= SIMPLE SPATIAL DISCRETIZATION
-Gradient= least Squares cell based
-Pressure= Presto
-Momentum= Second Order Upwind
-VOlume Fraction=Geo-Reconstruct
I enable Surface Tension force and wall adhesion. I adjust the value of contact angle and surface tension equal to 135 degree and 0.47.
Any other force is not applied to the slug. First I just want to study the performance of fluent on simulation of two phase flow.
When I run fluent, I find out the interface of slug is oscillating and the value of contact angle is not fixed equal to 135 degree.
How can I get ride of this oscillating?
Thanks in advance
amir.mofakham is offline   Reply With Quote
Old   April 14, 2013, 12:14
kbaker's Avatar
Khalid Baker
kbaker is on a distinguished road
Can you post a picture illustrates the interface motion this will give best understanding for your problem and give more chances to answered it?
kbaker
Originally Posted by amir.mofakham View Post
Hi
I used
-Pressure= Presto
Thanks in advance
kbaker is offline   Reply With Quote
Old   April 14, 2013, 17:52
amir mofakham
kbaker
Hi kbaker
Thank you for your attention.
I attached a picture. I hope this picture is clear to show my meaning.
Old   April 15, 2013, 10:27
kbaker's Avatar
Khalid Baker
Hey as I see from your image this type of flow is not slug. The water region just compressed and expands but why the water not move down the channel? what prevent it from moving?
Interface for Multiple reference of frame method Ehab44 FLUENT 4 April 12, 2013 04:48
VOF interface compression and mesh size idrama OpenFOAM 1 September 26, 2010 06:36
VOF vs Level Set Method for electrohydrodynamic waves Rowland Main CFD Forum 0 July 31, 2010 22:09
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 04:05
Inconstant Surface Tension on Interface in VOF Atieh CFX 4 February 10, 2007 15:47
