DO Model giving wrong results for optically thick media ?
Old   January 7, 2011, 08:58
Default DO Model giving wrong results for optically thick media ?
Salvatore Cunsolo
pprllo is on a distinguished road
First of all, hello everyone as this is my first post here !
Now, the problem.
I set up a very simple case, 2 walls at set temperature separated by a fluid. No gravity. No scattering.
Then i tried solving it:
- Without radiation
- With Rosseland radiation model.
- With P-1 radiation model.
- With DO radiation model.
Well, while Rosseland and P-1 results are consistent across a range of temperatures and absorption coefficient, I noticed that the wall fluxes calculated with the DO model are always higher than those calculated with Rosseland or P-1.
At this point i set the absorption coefficient at an extremely high value (10^9) and, while the Rosseland and P-1 models give me the predictable result (i.e. radiation heat transfer become negligible), the DO model still gives very high values of radiation heat transfer.
Any ideas ?
pprllo is offline   Reply With Quote
Old   January 11, 2011, 15:39
Salvatore Cunsolo
Upping the thread. Maybe someone has an idea.
Old   January 21, 2011, 12:45
Nikolopoulos Aristeidis
Nikolopoulos is on a distinguished road
Which version of fluent are you using?
Nikolopoulos is offline   Reply With Quote
Old   April 16, 2013, 21:27
gefei
i_flying is on a distinguished road
Now, the problem.
- Without radiation
Any ideas ?
I have get the same answer as you said, and when the optical thickness is very large, the convergence by do model with do/energy coupled is very fast , the P1 model is very low. which model you selected last?
i_flying is offline   Reply With Quote
Model of pump nonoptimal regimes get bad results Georg CFX 3 May 21, 2008 00:53
simulation results for k-w model and SST model Li CFX 7 June 29, 2007 04:19
multiphase model gives unreal results easycad FLUENT 14 April 17, 2005 07:52
standard k-eps model results? cfd Main CFD Forum 1 March 29, 2005 18:19
contradicting results of different turbulent model dani FLUENT 0 July 6, 2004 02:07
