Sphere-Fluid Heat Transfer
Old   April 26, 2013, 09:31
Default Sphere-Fluid Heat Transfer
Elina Mathew
elina is on a distinguished road
I have a sphere fluid flow in a channel.
I want to study conduction in the sphere
1) I create 2 zone ( 1 fluid zone and 2 for solid zone (sphere)).
2) I set all interfaces between solid and fluid to wall.
3) After exporting mesh to fluent, I see a -shadow boundary condition of type wall for each interface wall.
4) I enable heat equation. (knowing that the two wall are coupled)
5) Fluid flowing at 0.0001m/s water,370K
6) Sphere (copper) 300K initial temp.2spheres attached together....
Grid convergence has to be done...so Steady state simulation was tried...though the solution converges....
the problem after running simulation there no transfers conjugate between fluid and solid the temperature of solid remains stable (initial temperature).
Please help me ..give me suggestions regarding the Setup of case esp boundary conditions...
Thanks in advance......
elina is offline   Reply With Quote
Old   April 26, 2013, 14:50
diamondx's Avatar
Ghazlani M. Ali
diamondx will become famous soon enough
in the solution method, what scheme did you use ?? i suggest pressure coupled
Regards,
New to ICEM CFD, try this document --> https://goo.gl/KAOIwm
Ali
diamondx is offline   Reply With Quote
Old   April 27, 2013, 10:28
Elina Mathew
I used pressure velocity coupled-SIMPLE
and all second order upwind..
Old   April 27, 2013, 13:05
diamondx's Avatar
Ghazlani M. Ali
start by coupled. first order see how it looks
Regards,
Ali
Old   April 28, 2013, 20:31
Elina Mathew
Hi
Yes I tried that also..still the temperature at that outlet seems to be the same as 370 or 369.99 SO it means there is no conduction happening in the sphere...I mean the temperature is not transferred to the sphere from the fluid...What could be the reason..Any guess and can you tell what exactly this steady state will do in this kind of simulation....??
Heat transfer (conduction) between two pipes shields FLUENT 14 February 3, 2016 07:45
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 20:28
urgent: heat transfer fluid to solid marco FLUENT 1 October 28, 2005 22:17
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
