May 2, 2013, 08:20 |
Open Water Tank
Michael Bell
Rep Power: 13 |
Im currently studying the effects of jet flow in plunge pools which involves simulating firing a jet of water into an open surface water tank.
I am currently struggling to set up my boundary conditions for the tank and was wondering if anyone had any good pointers. I'm trying to use the VOF method but thus far have had no success. Any help or points would be much appreciated. |
May 2, 2013, 08:53 |
Philipp
Rep Power: 26 |
I would go these boundary conditions:
-velocity or mass-flow inlet for the water jet -pressure outlet for the ambient air -wall for the pool wall How do you plan to let the water leave the domain? Or do you want a rising surface / transient simulation? Maybe write a bit more about your setup and post some picture. What do you have for meshing. Is it 3d or 2d?
The skeleton ran out of shampoo in the shower. |
May 2, 2013, 10:30 |
Michael Bell
Rep Power: 13 |
The simulation is based on an actual experiment in which the water level remains constant so I've placed two outlets in the top corners of the tank. At the moment I have them as pressure-outlets. Do you think I should set them to outflow? I'm running the simulation in 2d and have currently have a 5mm sized quadrilateral mesh.
I'll attach an annotated screen shot of the tank. The purpose of the simulation is to study the diffusion of the jet in the pool so once I have the initial tank set up I can easily vary the jets velocity and diameter. Sorry for asking so many questions, this is the first time I have ever used the software. Thank you for your help so far. |
May 2, 2013, 10:37 |
Philipp
Rep Power: 26 |
1) What means "free water surface" at the top? Is this some kind of boundary condition?
2) It looks like you have water everywhere inside your domain. Why do you want to use the VOF model?
May 3, 2013, 07:03 |
Michael Bell
Rep Power: 13 |
By free water surface I mean that there is no rigid wall on the top of the tank and that the tank is open. I am unsure on what boundary conditions I should set that to?
As for the VOF I was unsure on the process and thought it might be a valid method for analysis. |
May 3, 2013, 07:15 |
Philipp
Rep Power: 26 |
VOF is a multiphase model. You only need it, if you want to have water and air inside your domain. If you have just water, there is no need to use it. So what do you plan?
May 3, 2013, 09:42 |
Michael Bell
Rep Power: 13 |
For the purpose of my work the analysis does not need to be time dependent so therefore I will set my time to steady. Since the inlet jet is meant to be turbluent I will set viscous solver to k-epsilon. I will set my domain as water-liquid then focus on my boundary conditions.
Like you've previously mentioned, walls will be wall, inlet will be set to velocity-inlet and outlets set to outflow. I've read on other threads that I can set my water surface to wall and put the shear equal to 0 to simulate the water's surface. I will also try setting the surface to pressure-outlet. Finally, I will initialize the model computing from the inlet and run my calculations. What do you think of my method thus far? |
May 3, 2013, 09:52 |
Philipp
Rep Power: 26 |
Sounds good. I never use the "outflow" bc. Don't know why, but up to now pressure and velocity/massflow was the choice
May 3, 2013, 09:55 |
#9 |
Michael Bell
Rep Power: 13 |
Brilliant. Thank you for your help! I'll let you know how I get on.
Filling Tank with Water | leff | CFX | 7 | August 21, 2017 07:47 |
[swak4Foam] build problem swak4Foam OF 2.2.0 | mcathela | OpenFOAM Community Contributions | 14 | April 23, 2013 13:59 |
OpenFOAM 1.6.x - CentOS 5.3 x86_64 | linnemann | OpenFOAM Installation | 68 | April 22, 2013 11:03 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
OpenFOAM with IBM AIX | matthias | OpenFOAM Installation | 20 | March 25, 2008 02:36 |
