Vacuum in FLUENT
Like Tree3Likes
  • 1 Post By RodriguezFatz
Old   June 8, 2007, 13:43
Default Vacuum in FLUENT
Shanti
Hi
I want to know how to create vacuum in FLUENT. I have given the operating pressure as 0 Pa. But I dont think it is creating a vacuum that way as I could see the recirculation of air. Can anyone help me with this?
Thanks,
Shanti
Old   June 8, 2007, 14:07
Default Re: Vacuum in FLUENT
A A S
maybe you could try turning off the flow equations in the solution control panel. Also, be sure you have zero gauge pressure in all your boundary conditions
Old   June 8, 2007, 14:23
Shanti
Hi
Thanks for your reply. But I am solving for the interface tracking of a fluid. Won't turning off the flow equations affect that?
Thanks,
Shanti
Old   June 8, 2007, 14:52
Vivek
Navier Stokes equations which are solved in Fluent are not valid in very low pressures.
Old   June 8, 2007, 16:01
Shanti
Hi
When I deselected the flow equation, vacuum has been created. But I am not able to study the forces acting on the walls. Is there any way I can study that?
Thanks,
Shanti
Old   June 8, 2007, 16:40
kk
can you define the 'low pressure' range. How low is that low?
Old   June 11, 2007, 13:57
Will
If your Knudson number is greater than 1/10, then Navier-Stokes is not valid.
Old   June 11, 2007, 14:03
Shanti
There is no specific range for pressure. I just want to create vacuum.
Old   January 17, 2013, 03:16
Default create vacuum
Vaze
mvee is on a distinguished road
Hi
Did you create vacuum and able to solve the NS equations? How?
Thank you
mvee is offline   Reply With Quote
Old   January 17, 2013, 04:35
RodriguezFatz's Avatar
Philipp
RodriguezFatz will become famous soon enough
No, he wasn't. No one can do that. Fluid equations without any fluid just don't make any sense at all.
biscarri likes this.
The skeleton ran out of shampoo in the shower.
RodriguezFatz is offline   Reply With Quote
Old   January 17, 2013, 23:26
Vaze
Hi RodriguezFatz
You are exactly correct. Perfact vacuum can not be modelled. I have following questions:
(1) Can we model low pressure 1e-5 Torr and solve it by compressible flow equations?
(2) If the pressure of 1e-5 Torr is not possible then what is the minimum pressure we can go?
(3) How Knudson number is related to compressible flow?
Your reply is very much helpful to me.
Thank you
Mvee
Old   January 18, 2013, 02:18
Philipp
To all your questions:
Knudsen number is the mean free path for atom/molecule collisions divided by the size "L" of your domain. It means: How many collisions occur, when a particle travels through your domain (Kn is the inverse of that number). If the number of collisions is large enough the gas can be considered to be a continuum.
Thus, you can answer these questions only if you know L.
Old   May 3, 2013, 09:17
Default seeking help related to vacuum...!!!!
  #13
Sumeet Kotak
sumeet kotak is on a distinguished road
Hello RodriguezFatz sir,
I am simulating Electron beam physical vapor deposition system (EB-PVD) for coating of evaporant on substrate. For improvement of purity of coating, I required vacuum inside the chamber. The amount of vacuum required at least 3e-5 mbar using (0.005 Pascal) (practically measured value).
so can u help me how can i create vacuum inside the chamber...???
how to set operating pressure in operating condition dialogue box and pressure outlet pressure in boundary condition dialogue box....???
0.005 Pa is measured using vacuum gauge, practically, by performing experiment.
sumeet kotak is offline   Reply With Quote
Old   May 3, 2013, 09:23
Philipp
Please read the posts of this thread and you will see that it is absolutely senseless to use Fluent for this case.
Old   May 3, 2013, 09:33
Sumeet Kotak
thanks for replay sir...
sir in knudsen no. how to calculate mean free path length.. ie. distance between two particle just before collision?
Old   May 3, 2013, 09:55
Philipp
Have a look at:
http://en.wikipedia.org/wiki/Mean_free_path
Take the first formula of section "mean free path in kincetic theory" and put in your gases density and collision cross section!
Although I don't expect that your particle distribution will be maxwellian...
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Vacuum in FLUENT Shanti FLUENT 0 October 19, 2006 18:41
