May 13, 2013, 13:55 |
Transonic Inviscid Turbine Cascade
Hey guys,
I’m trying to replicate the transonic, inviscid results of an inverse turbine blade design thesis. I have the original blade geometry, and have more or less copied the original mesh. The original geometry is discontinuous, leading to a passage shock at the discontinuity (I’ve attached geometry and Mach contour images). In the thesis, the ratio of back pressure to stagnation pressure is given as 0.65, so I’ve been using a pressure inlet and outlet and just picking pressures that correspond to that ratio. However, if I’m using lower pressures, i.e. Po = 100 kPa and Pback = 65 kPa, I don’t get a shock at all. As I increase both pressures (Po = 10 000 kPa, Pback = 6 500 kPa), I am getting the shock, but it’s upstream of the discontinuity (shown in the 3rd attached picture). I’d really appreciate any advice as to what I can do to improve these results. Thanks. |
May 22, 2013, 10:20 |
Just an update - I've managed to get what looks like a pretty good replica of the original results, using a stagnation pressure of 50 000 kPa and back pressure of 32 500 kPa. The shock appears to be occurring in the same place as the original work, and comparing upstream and downstream Mach numbers in both cases (0.483 vs. 0.478 and 0.819 vs 0.803) shows good agreement. Additionally, the mass flow through the passage has only 0.39% difference between the two cases.
However, if anyone has any ideas how I could get these results without having to use as high pressures, I would appreciate it. Thanks! |
VKI Turbine Cascade | Apurva | Main CFD Forum | 9 | September 22, 2021 15:42 |
Heat Transfer Coefficient in Compressible Flow 3D turbine cascade | Karkoura | CFX | 0 | March 10, 2011 15:35 |
Inviscid Transonic flow of Naca 0012 | pankos | Main CFD Forum | 4 | February 13, 2011 04:59 |
Want to get secondary flow in 3D turbine rotor cascade | darshak | FLUENT | 0 | December 2, 2009 13:18 |
Simulation of turbine cascade in CFX. | Jonas Pedro Caumo | CFX | 0 | December 9, 2006 13:54 |
