Lagunesvary
Rep Power: 13 ![]() |
hai, thanks for ur time...
![]() im simulating heat exchanger. can i use coupled solver? as from user guide, it says; can use large time step size... well im wondering what is the range of time step size can be used.. ![]() |
Stephan Langenberg
Rep Power: 14 ![]() |
There is no general answer for long and short time steps. If you have an heat exchanging process and you want to know what's happening in the first 1 mm ouf your solid fan, radiator or.... you may need very short time step sizes. If you are only interested in your stationary final value then a transient case isn't needed (if the model fits). It is a compromise on calculation time, exactness and your personal requirements. In simple cases you can run a simulation at two time step sizes and compare the results... |
coupled solver |
Working directory via command line | Luiz | CFX | 4 | March 6, 2011 20:02 |
coupled solver wont work in star ccm+ | richie | Siemens | 5 | November 4, 2008 04:51 |
segregated solver vrs coupled solver | sm | FLUENT | 0 | November 6, 2007 01:24 |
The seperated solver and coupled one | summer | FLUENT | 0 | July 5, 2006 15:06 |
compressible two phase flow in CFX4.4 | youngan | CFX | 0 | July 1, 2003 23:32 |
