Oscillation airfoil in infinite water depth
Old   May 30, 2013, 22:30
Default Oscillation airfoil in infinite water depth
Lee,Dong Beom
ldb83 is on a distinguished road
Hello~ I am a beginner for FLUENT.
Now I am simulating the oscillation airfoil in infinite water depth.
I used pressure-based and UDF for the motion of oscillation.
also standard k-e model is used for the model.
water flow from left boundary with 2.0 m/sec^2 and the frequency of body oscillation is 5Hz.
Question
1. I give no slip condition to the upper and lower wall to consider infinite water depth. I am not sure it is enough or not? Should I give additional consideration to the boundary?
2. I am wondering standard k-e model is suitable for this kind of simulation.
Have a nice day all of you~
ldb83 is offline   Reply With Quote
Old   May 31, 2013, 04:39
Stefanos Katifeoglou
stefanos is on a distinguished road
for infinite boundaries, and more specifically, for solutions that require the viscous fluid not to reflect on the boundary, i think that the "pressure farfield" condition is a more suitable option, however it's setting up is a bit more complex than the other BCs. I haven't worked on it so i can't tell you more. You can check out the manual on that.
stefanos is offline   Reply With Quote
Old   May 31, 2013, 04:42
however, as long as the oscillation amplitude of your airfoil is not extreme, for your domain i don't think that you'll have any problem retaining the no-slip BCs
Old   May 31, 2013, 17:43
Lefteris
Aeronautics El. K. is on a distinguished road
1. m/s^2 are units for acceleration, not for velocity, right?
2. There are 2 papers titled "Evaluation of turbulence models for unsteady flows of an oscillating airfoil" by Srinivasan, Ekaterinaris and McCroskey and "computation of separated and unsteady flows with one- and two- equation models by Ekaterinaris and Menter, which could answer your questions about the turbulence model.
Lefteris
Aeronautics El. K. is offline   Reply With Quote
Old   May 31, 2013, 20:05
Lee,Dong Beom
Thank you for your kind reply. It will be very useful for my simulation~
1. It's my mistake. I have used m/s for velocity.
2. I will review the papers mentioned by you.
Lee,Dong Beom
Old   May 31, 2013, 20:11
Lee,Dong Beom
Thank you for your kind reply. Can I add one more questions?
I have seen some simulation using pressure-outlet to consider infinite depth.
Do you think that pressure-outlet condition is more suitable than no-slip condition??
Old   June 1, 2013, 05:51
Lefteris
May I ask what exactly do you mean by "infinite water depth"?
I believe there's not such thing. Water depth is finite and max depth is somewhere in the Pacific and counts about 11km.
The no-slip condition doesn't define the depth. Neither does so the pressure outlet.
I think that the depth should be defined via the operating pressure.
Lefteris
Old   June 2, 2013, 01:05
Lee,Dong Beom
It means that any boundary condition is not considered in my simulation.
so I would like to consider only the effect from oscillating airfoil.
If the airfoil is oscillated in shallow water depth, there is some wave reflection from bottom boundary. however In my simulation, I don't want to consider that kind of effect.
so now I am little bit confusing should I define the upper and lower wall as pressure-out.
I am not sure my interpretation is enough or not.
Old   June 2, 2013, 06:15
Lefteris
Hello Lee!
I just noticed at the pictures you uploaded that the inlet and outlet boundaries are only 12m apart while your airfoil's chord is 1m. It is quite probable then, that the boundaries will influence the solution that's why you should increase this distance.
I guess that by "upper and lower wall" you mean, actually, the upper and lower boundaries of your domain. In this case, I think you should do what Stefanos suggested and define them as pressure far-field.
Lefteris
Old   June 2, 2013, 06:59
Lee,Dong Beom
Hello Lee!
Mr. Lefteris~
Thank you so much your recommendation.
I was thinking the distance is too short compared to chord length.
so I am planing to increase the domain length as 40 times of chord length.
also the upper and lower boundary is changed to pressure-outlet.
I think that It could be also reasonable boundary condition compared to pressure far field.
anyway Many thanks~
Old   June 2, 2013, 07:06
Lefteris
You're right. A little revision in fluent's user's guide helps.
Pressure outlet is the general condition... Pressure far field is recommended for compressible flow. I was wrong on that, sorry.
Lefteris
Old   June 3, 2013, 02:09
Lee,Dong Beom
Thank you so much for you comment.
Your comment was very valuable for my simulation.
Have a nice day~
Old   June 4, 2013, 07:25
mohammed ibrahim
mhmmad_ibraham is on a distinguished road
Hello sir...
please send me your udf of oscillation motion as fast as you can...
my E_mail is m70hm@yahoo.com
mhmmad_ibraham is offline   Reply With Quote
Old   June 4, 2013, 08:03
Nitish Singh
nitman118 is on a distinguished road
Send a message via Yahoo to nitman118
hi,
can you share your udf with me....it will be really helpful,thanks.....
nitman118 is offline   Reply With Quote
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 09:26
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
dynamic mesh airfoil oscillation aamer Fluent UDF and Scheme Programming 0 January 25, 2011 07:29
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 09:11
uptodate water distribution network fredius,magige,tanzanian,(e.a) Main CFD Forum 0 January 27, 2002 07:10
