May 25, 2013, 16:16 |
Simulation the free convection in fluent
ashkan
Rep Power: 12 |
Dear all,
I want to simulate natural free convection in fluent but I cant.I do this thing up to now and I cant reach to answer: 1-In operation condition I give -9.81 in the y part. 2-I give the density of water(my channel is full of water) in businesqe please help me |
May 26, 2013, 06:16 |
free
ashkan
Rep Power: 12 |
I cant understand any thing
May 26, 2013, 15:50 |
alireza
Rep Power: 12 |
hi. its steady or unsteady simulation.
May 27, 2013, 02:38 |
free
ashkan
Rep Power: 12 |
Unsteady 3D simulation
May 27, 2013, 11:14 |
alireza
Rep Power: 12 |
3d+natural+unsteady simulation is out of the power of normal computer.
change your problem into 2d if you use temperature bc increase its value to see the result sooner reduce the mesh in your problem to use less memory of your computer your time must be large to see anything. |
May 28, 2013, 07:50 |
free
ashkan
Rep Power: 12 |
I don't have problem about memory only I can't simulate natural convection.
May 28, 2013, 16:21 |
alireza
Rep Power: 12 |
what about time of your simulation?
by small time you cant see any changes in domain of natural sim. so you must use large time: by: little time step + large number of time steps + large iteration number in each time step + 3d + natural + small mesh + high order of solving = be sure you will have memory problem of using normal computers. if you don't have memory problem just you must insert large time for natural simulation to see changes in domain another way is to increase the value of the bc ( if you are using temperature bc ) to have more influence on your fluid. if I were you first I simulate it steady after it try to solve it unsteady , cause of for being sure it is true. if you like . can you send me case & data file of your problem.(little size . before solving ) alireza9359300@yahoo.com |
May 30, 2013, 03:48 |
Jim Knopf
Rep Power: 15 |
And don't under relax the enegry equation
May 31, 2013, 17:33 |
#9 |
alireza
Rep Power: 12 |
I think your problem is density (change it to compressible fluid not boussings)
I sent it for you. |
June 1, 2013, 03:52 |
#10 |
Jim Knopf
Rep Power: 15 |
He already said he's using Boussinesque ansatz, that should work.
As he is writing about a channel, it sounds to me as if he is trying to solve a Rayleigh-Benard convection type of problem. That always takes a while to start. To force starting the convective motion one could initialize the field with a smal amount of velocity in the assumed direction of motion. Anyways, more info is needed. Greetz Jim |
Chemical Equilibrium Simulation using Fluent | enigma | ANSYS | 2 | October 27, 2011 08:02 |
Free surface simulation | Moti | ANSYS | 0 | August 13, 2009 13:41 |
Fluent simulation over airships | Aragon | FLUENT | 8 | March 30, 2009 12:12 |
Fluent simulation over airships | Aragon | FLUENT | 0 | March 27, 2009 12:38 |
Can Fluent solve free interface problem? | xueying | FLUENT | 3 | July 18, 2002 15:29 |
