segmentation violation in ansys 12
Old   June 7, 2013, 07:53
Default segmentation violation in ansys 12
Chris
chris20 is on a distinguished road
I am running a LES on a non-conformal mesh in ANSYS FLUENT 12 in parallel processing mode. Simple UDFs for inflow profiles are involved.
After a few thousand iterations, the simulations crashed and the error message was:
stack backtrace generated for node id ...
primitive error at node ...: received segmentation violation
When I now try to restart the simulations, the UDFs (though still in the same directory) are not found anymore and have to be complied again and the simulations crash immediately with the same error messages as above.
This happens when I (re)start the simulation from the original cas-file (i.e. those starting from iteration 0 which was already running for a few thousand iterations), or when I try to continue from a cas-file with xyz iterations. I also tried different processors, but the problem remains.
Chris
chris20 is offline   Reply With Quote
ansys 12, les, non-conformal mesh, segmentation violation, stack backtrace
Segmentation violation louiza FLUENT 16 June 27, 2017 15:41
[ICEM] Segmentation Violation crashing ICEM siw ANSYS Meshing & Geometry 3 February 10, 2014 06:52
Segmentation Violation Corentin FLUENT 1 February 13, 2011 01:07
Defining Multiphase by text and by gui = different result and Segmentation Violation RPJones FLUENT 0 June 9, 2009 16:24
segmentation violation wasan FLUENT 0 December 23, 2008 11:37
