orthogonal permeability-resin infusion with FLUENT Software
Old   June 17, 2013, 02:53
Question orthogonal permeability-resin infusion with FLUENT Software
hadi
hadi.iraji is on a distinguished road
Dear all
I want to analyze orthogonal resin infusion with FLUENT Software and I do not have permeability parameters for wide oblique shapes such as circular or oval shapes. Is it possible to use/expand experimental data (permeability parameters of Kx, Ky, Kz) obtained from a small flat surface? Please note that the permeability of a flat surface is fixed in all directions (x,y,z) but in a circular shape the parameters change according to the perpendicular curve coordinates. For example at the bottom of a circular curve, the thickness direction is parallel to Z axis (Z1) while at the sides it is perpendicular to the Z axis (Z2).
I really appreciate your help and effort for this research. Z2 Z1
hadi.iraji is offline   Reply With Quote
Old   June 17, 2013, 02:55
Default prof.soza
hadi
It would be no problem to expand the permeability parameters from a small plate to a larger one, however in you case you have a curvature.
The problem relies in the fact the your permeability parameters are align with the reinforced media fibers and in the mathematical model they are fixed according to the x, y and z axis.
Are you using FLUENT? I have never solved anything like this and I'm not sure that you can do it with FLUENT. I know that you can change the permeability parameter orientation, however I think it is not possible to have them varying within the cells (volumes).
In the window that you define the permeability parameter (in FLUENT) there is a button called "conical". It may be what you need, but I'm not sure.
Old   June 24, 2013, 06:08
Default ?
hadi
Old   July 7, 2013, 04:06
hadi
from where i can get fluent software *NM* Prateek kumar Jain Main CFD Forum 2 January 18, 2008 00:55
modeling of free boundary in Fluent Software Mahmoud Alidadi Main CFD Forum 1 August 12, 2005 09:12
which cfd software is best. fluent , cfx. or...... sijal Main CFD Forum 13 October 6, 2004 09:54
Buying fluent software Julytli FLUENT 3 March 30, 2004 20:35
Fluent software dimitris FLUENT 1 July 1, 2002 09:35
