July 8, 2013, 09:35 |
Eulerian VOF method-outlet boundary?????
sajeesh
Hi
I am doing a 2D simulation for the movement of a water droplet having Diameter 25 micrometer through a channel of cross scetion 50 micro X 500 micro.. Using Eulerian VOF coupled method to explicitly define the velocity of droplet and oil phase I patch the droplet phase and assign a volume fraction of 1 to that water droplet patched region I am using transient case with double precision Oil as primary phase and secondary phase as droplet scheme: phase coupled SIMPLE gradient : Least sqaure method Momentum : first order upwind volume fraction: geo construct Inlet BC: velocity for oil and droplet volume fraction zero and droplet velocity also at inlet when i am using Outlet boundary condition I have to define the back flow volume fraction. initially If i give the back flow fraction as 0 the simulation running fine and give the correct tracking of interface also For me i want to eject the droplet from the exit.But by this condition after the simulation the droplet is stuck at exit.solution gets stopped by the high courant number Similarly i tried with outflow BC.at that time also simulation perfect upto reaching the outlet then again the simulation stopped and the droplet is not going out. When i tried outlet boundary condition with back flow volume fraction of droplet as 1 it is showing error ->Solution diverging ..velocity diverging .Global courant number more than 250.. Please help me to eject the droplet from the channel during simulation.For that what BC should i give at outlet... My email ID sajeeshperil@gmail.com Thanking You sajeesh |
July 10, 2013, 04:34 |
Rep Power: 12 |
I am also working on similar Project on wetting Dynamics of an indium droplet. Can you send me your files, so that I can recommend something mehmet.yigit.balta@gmail.com |
July 10, 2013, 08:25 |
sajeesh
sir what files you want....
case and data file |
July 10, 2013, 09:26 |
Rep Power: 12 |
yes please send me case and last data file so that i can look through
September 23, 2013, 01:38 |
sajeesh
sir
did you get my mail..have seen the files....pls reply me..if you got it Sajeesh |
September 23, 2013, 01:59 |
sajeesh
sir
September 26, 2013, 03:34 |
droplet
Rep Power: 12 |
Hi saajesh:
I think you should try like this: 1 Finer mesh VOF method instead of Euler Implicit instead of explicit Servers: Pressure based Coupled Least square cell based Quick Quick Small time steps (like 1e-6) My droplet and tank project with wall adhesion worked like this Sorry for the late answer, Good luck! |
September 26, 2013, 09:39 |
sajeesh
Thanks sir for reply
How i can give velocity for the droplet if i select the VOF model I want to give different velocity for the droplet. To study the internal external velocity vectors at differnt flow rates of discrete phase Sajeesh |
UDF Defining VOF Free Surface at Outlet | Alex | Fluent UDF and Scheme Programming | 13 | August 8, 2012 16:50 |
Disturbed flow field at outlet boundary (Multiphase flow through pipe) | Michiel | CFX | 17 | April 21, 2010 10:14 |
Implications for heat transfer when outlet pressure boundary condition used | Blob | CFX | 2 | March 26, 2009 06:22 |
outlet boundary condition | Nina Schiepel | CFX | 2 | July 12, 2008 15:27 |
outlet boundary of eulerian model? | star123 | FLUENT | 4 | April 2, 2005 22:43 |
