June 25, 2015, 15:54 |
Similar problem (2 possible solutions)
Wisconsin
I am working on similar problem, a closed loop with heat generation. I want to track how the temperature in the loop changes over time.
The two ideas I have are involve breaking the loop into several zones so that I have at least 1 straight section of pipe. I then either: 1) Use a momentum source term 2) Use a fixed velocity term on the straight section of pipe. This works to an extent (I get continuous and flow through the loop in one direction). however, a momentum source term is difficult to use to control the velocity and for some reason the velocity in the loop is not equal to what i set as the fixed term. very odd Any tips would be much appreciated. |
boundary condition, closed loop, fluent |
Review: Reversed flow | CRT | FLUENT | 1 | May 7, 2018 05:36 |
Ansys Fluid flow simulation for a cooling system help!!! | pradon16 | ANSYS | 0 | July 24, 2012 10:15 |
Modeling the mixing of air and kerosene in a flow channel | StefanG | CFX | 3 | June 11, 2012 20:21 |
Closed loop pipe flow | maddalena | OpenFOAM Running, Solving & CFD | 34 | August 16, 2011 11:46 |
mold flow modeling | Pei Hsieh | Main CFD Forum | 0 | May 4, 2005 10:08 |
