reversed flow
Old   July 12, 2013, 16:23
Default reversed flow
sajjad bouzari
bouzari2012 is on a distinguished road
hi every one
I'm modeling blood flow in Aorta and I have velocity inlet boundary condition and pressure out lets when I try to iterate, I see this in fluent " reversed flow in xx faces on pressure outlet x". I can't change my boundary conditions so can you help me fix the problem.
and also my case is Laminar , steady ,3d and i use "Least Squares Cell Based"
I really need your help
best regards
bouzari2012 is offline   Reply With Quote
Old   July 14, 2013, 23:12
cdegroot's Avatar
Chris DeGroot
cdegroot is on a distinguished road
Looks like your problem is not converging very well. Try adjusting relaxation settings and maybe try coupled solver. Also make sure the outlet is far enough downstream that back flow wouldn't be expected physically.
cdegroot is offline   Reply With Quote
Old   July 15, 2013, 02:27
Smile Check
Jasdeep
jasdeep2006singh is on a distinguished road
Check your flow direction as well. Or let it iterate for some time, it might stabilize.
jasdeep2006singh is offline   Reply With Quote
Old   July 15, 2013, 03:04
Firas
Firas is on a distinguished road
I agree with our friend check comment ....let your iteration go ahead and see the result in quess reversed flow will finish after numbers of iterations
Firas is offline   Reply With Quote
Significant Reversed Flow at Outflow Problems [ANSYS FLUENT] NormalVector ANSYS 1 May 15, 2012 23:50
Reversed Flow for a tenth slice of a rotor neptunemmx FLUENT 10 January 30, 2012 13:51
Reversed flow...>>>Please HELP...! sushii FLUENT 14 October 29, 2007 04:27
reversed flow at velocity inlet / mass flow inlet ib FLUENT 1 March 26, 2007 13:11
reversed flow Sastry FLUENT 5 March 22, 2007 08:05
