Flapping fin thrust in FLUENT
Old   July 5, 2012, 16:58
Default Flapping fin thrust in FLUENT
Ajinkya Desai
jinks is on a distinguished road
hey, I am simulating an oscillating/flapping fin in FLUENT. I plotted the cd vs the flow time and if the time averaged Cd comes out negative then it amount to a net THRUST rite? I need to know if this is the best way of calculating thrust. Also i should tell you, that for this oscillating fin, the average drag is coming out positive, contradictory to our hypothesis. Some one please help me with this.
Thank you.
jinks is offline   Reply With Quote
Old   July 5, 2012, 17:30
Casey
meangreen is on a distinguished road
It depends what surface you are defining your drag. (also on how you are defining your force) Think about it, it is going to be positive for one surface/phase and negative for the other. As air flows over a fin there will be a negative drag force for the air (the air is decelerating as it drags across the fin) but positive for the fin (the equal and opposite drag force from the air is implemented onto the fin).
meangreen is offline   Reply With Quote
Old   July 19, 2013, 19:34
Default Cd vs Flow time
Mohammad Ashraf Hossain
cgpa4 is on a distinguished road
I want to plot the curve for Cd vs flow time for a flow past cylinder. I tried by going to surface. But its not working. Please help me on it.
Mohammad
cgpa4 is offline   Reply With Quote
Two questions on Fluent UDF Steven Fluent UDF and Scheme Programming 7 March 23, 2018 03:22
Error in reading Fluent 13 case file in fluent 12 apurv FLUENT 2 July 12, 2013 07:46
Fluent 6.3 32bit vs Fluent 12.0 64bit ibex7 FLUENT 7 April 18, 2011 02:44
Problems in lauching FLUENT Lourival FLUENT 3 January 16, 2008 16:48
2D flapping foil- moving ref frame model in Fluent VJ FLUENT 0 October 20, 2007 01:15
