oscillation of residues !
Old   July 25, 2013, 14:33
Default oscillation of residues !
rayan
rayan24 is on a distinguished road
I don't understand why the residues begin to oscillate from 6000 iterations in my case! before 6000 iterations the residues appear to decrease normally, but after starting to oscillate, is anyone has explanation please
rayan24 is offline   Reply With Quote
Old   July 26, 2013, 08:50
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
As always, more information is needed to provide a conclusive answer.
Usually, oscillating residuals indicate that the round-off accuracy of the machine is reached. At this point, the solution is really converged.
flotus1 is offline   Reply With Quote
Old   July 26, 2013, 09:03
rayan
Thanks for your replay
Here's the link of the residues
https://docs.google.com/file/d/0B3mx...it?usp=sharing
Thanks for help
Old   July 26, 2013, 09:12
Ali Mohamadi
Alimohamadi_nasr is on a distinguished road
i think it can have two origin, the first one is that the number of your meshes is not enough and the second one is that you cannot solve it as a steady state and you should change it to transient mode. do you have reverse flow in your domain? if yes, what its percentage of reverse flow ?( the number of cell you have reverse flow/total number of cell on your boundary that you have reverse flow)
Alimohamadi_nasr is offline   Reply With Quote
Old   July 26, 2013, 09:19
rayan
I don't think it could come from the mesh because I have more than 3 million cells, and I think if it comes from the mesh I had to have these oscillations at the beginning of the simulation and not after 4000 iterations? no?!
No, I don't have a reversed flow
Old   July 26, 2013, 09:36
Ali Mohamadi
I suggest change it to transient mode. i have mentioned that it can have two reasons.
Old   July 26, 2013, 09:46
rayan
Thanks for your replay but I specify that similar simulations have been performed with steady mode
Old   July 26, 2013, 09:50
Ali Mohamadi
can you determine difference between your two simulations? both of them have same boundary condition and same regime flow?
Old   July 26, 2013, 09:56
rayan
I said that similar simulations are realised in the passe and not the same case! have been made ​​by other persones in the litiratures !
Old   July 26, 2013, 22:27
François Grégoire
macfly is on a distinguished road
Hi Ali,
What do you have in mind when asking this question? Are you relating reverse flow to too coarse mesh or to steady/transient?
macfly is offline   Reply With Quote
Old   July 26, 2013, 22:43
Ali Mohamadi
Hello Macfly
no, about reverse flow, I have been only curious that it happens or not.
Old   July 27, 2013, 10:51
Far
Sijal
Far has a spectacular aura aboutFar has a spectacular aura about
Send a message via Skype™ to Far
Thanks for help
Solution is converged. Did you check any other parameter of interest ?
Far is offline   Reply With Quote
Old   July 27, 2013, 14:18
rayan
Thank you Sijal Ahmed for your replay,
if the solution is converged why Residues oscillate? I know, you can correct me if I'm wrong, that the convergence is achieved when Residues stabilize (ie no change or a very small change of residues), Can you confirme me this analysis of convergence please??
Occasionally when I check the result I perceive it is not converged (because i fixed 1e-3 not enough I suppose).
Old   July 27, 2013, 14:40
Far
Sijal
If you are not satisfied then it can be a problem of mesh.
What does convergence means? It is possible that in few cells you have problem in convergence due to mesh or some other flow problem and that may not be important for your simulation. So it will give you oscillatory convergence pattern. but I see there is not much oscillation from the mean value.
Moreover when we check convergence, it means
Old   July 27, 2013, 15:05
rayan
Thanks for likk,
in fact the first explanation in the link is that the residues must be no changes .. apparently my mesh is constricted as well, but I'll try to redo the mesh then see
Old   July 27, 2013, 15:16
Far
Sijal
I would not suggest redoing mesh without any reason
Old   July 27, 2013, 15:35
rayan
OK,
So could you confirm to me that my residues in top don't pose a problem and we can consider that the solution is converged in your opinion??
N.B : I'm begining in CFD modeling
Thanks
Old   July 27, 2013, 15:53
Far
Sijal
I think it is. What are you modelling? What parameters you are looking for?
Old   July 27, 2013, 17:08
rayan
I model the aeraulic flow and temperature distribution in a vehicle...
is the nature of the residues in top are not embarrassing?? Have you met during your career in CFD similar convergence?
Old   July 27, 2013, 17:17
Far
Sijal
Yes many times while simulating in Fluent. In CFX either you will get fully convergence or no convergence at all, while Fluent tries, tries and sometimes for ever.
Maybe you should play with some parameters of solver like relaxation for high order terms, applying pseudo transients, hybrid initialization...
Oscillation airfoil in infinite water depth ldb83 FLUENT 14 June 4, 2013 08:03
QUICK scheme oscillation kongl1986 FLUENT 4 April 4, 2012 16:22
residues tanveer CFX 1 April 3, 2009 07:24
Oscillation problem Pavel FLUENT 0 August 17, 2004 13:38
jet oscillation at low inlet Re wood Main CFD Forum 1 October 21, 1999 13:45
