July 30, 2013, 14:35 |
Problem with boundary conditions
Laura M
I am trying to design a flip flop jet device on gridgen/fluent to see the flow and the velocity oscillations. I am novice in CFD and I have a lot of problem with these two softwares even after reading the tutorials. I managed to create the model on Gridgen, I made a domain with the outer edge and the two walls inside. I also created the block and exported the file via "export analysis data" to a .cas file I opened in Fluent. However, in the boundary conditions of Fluent I don't see how to set the inlet walls, outlet walls (they don't appear as zones) and i don't know how to define the inside walls. Thank you very much for your help Laura |
gridgen fluent |
ribbed channel / simpleFoam / boundary conditions | beeo | OpenFOAM Pre-Processing | 20 | July 17, 2013 08:39 |
Problem with Periodic Boundary Conditions Help!!! | otsigun | FLUENT | 0 | July 11, 2013 03:20 |
Boundary Conditions problem | o_mars_2010 | Main CFD Forum | 2 | July 8, 2013 02:10 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Problem with Boundary conditions | Mahiboobswamulu | Main CFD Forum | 10 | August 26, 2003 13:24 |
