chemkin fluent
Like Tree1Likes
  • 1 Post By mythealias
Old   August 5, 2013, 04:59
Default chemkin fluent
hamdireza is on a distinguished road
hi
i need simple tutorial for creating chemkin mechanism and importing in fluent
i can work with chemkin and fluent but i dont know how use chemkin with fluent
i know i must import .che format in fluent but i dont know how create .che file
i download .dat mechanism amd therm file from ECR but i dont know how convert this file to . che
please help
hamdireza is offline   Reply With Quote
Old   August 10, 2013, 15:30
mythealias is on a distinguished road
Since you already know hoe to work with chemkin, you can directly import the mechanism files to fluent using the File > Import > Chemkin mechanism ...
You do not need to change the file format. If the files worked with Chemkin preprocessor, then they are in correct format to import. btw Fluent will only work with mechanism with 50 species or less.
Example here: http://aerojet.engr.ucdavis.edu/flue...g/node1301.htm
hamdireza likes this.
mythealias is offline   Reply With Quote
Old   August 10, 2013, 18:09
thanks a lot
it help me
Old   May 20, 2014, 03:00
Post from where i can get 4 step peter mechanism chemkin file
Tarandeep Singh Sohal
Singh is on a distinguished road
i have to use peter mechanism for my 3d combustion on fluent... i need this che file to use
as i had already used 21 step chemistry can i edit it and transform it to my desire... if yes then how?
Singh is offline   Reply With Quote
Old   March 8, 2015, 15:54
sanjeet Limbu
sanjeetlimbu is on a distinguished road
can we use chemkin file with 180 species ?? If not is there any way to transform it to use in fluent
sanjeetlimbu is offline   Reply With Quote
Old   July 27, 2015, 13:54
Philip Wang
philipwang1989 is on a distinguished road
I guess you need to use reduced mechanisms.
Or you can eliminates some of the reactions (for instance, N2 reactions) by assuming it's an inert if you have the right problem statement.
philipwang1989 is offline   Reply With Quote
fluent parallel problem in win7 x64 system dunga82 FLUENT 8 April 19, 2012 20:23
What the differences flow equation of Fluent 6.3 and Fluent 12.1 opehterinar81 FLUENT 0 August 19, 2011 11:55
On Bug of Fluent 12.0 lzgwhy FLUENT 0 August 26, 2009 06:41
chemkin -> fluent Tomasz ochrymiuk Main CFD Forum 0 March 16, 2000 05:55
chemkin -> fluent Tomasz Ochrymiuk FLUENT 0 March 16, 2000 05:11
