Aircraft in Roll Maneuver
Like Tree1Likes
  • 1 Post By husker
Old   September 3, 2013, 12:29
Default Aircraft in Roll Maneuver
Gonzalo
gfoam is on a distinguished road
Hi everybody:
I want to simulate an aircraft in a roll maneuver in FLUENT. The maneuver is stationary, namely, the forward and angular velocity are constant and the flow is incompressible. I think this could be done via the moving refrence frame formulation or via the sliding mesh approach. The second approach has a higher computational cost than the former but, which one is the correct? Or which one has the resilt more accurate? Thanks in advance
Gonzalo
gfoam is offline   Reply With Quote
Old   September 4, 2013, 02:57
husker is on a distinguished road
Is the maneuver steady? I mean is the aircraft rolling steadily like a bullet disrupting the air? This sounds a little interesting to me.
If the problem is time dependent, you may need the use of dynamic mesh. At that time, I think only one steady boundary condition (cruise speed) will enable to simulate maneuver.
Regards
like.no.other likes this.
husker is offline   Reply With Quote
Old   September 4, 2013, 05:25
Exclamation
Centurion2011's Avatar
Centurion2011 will become famous soon enough
Sliding mesh in usualy modelled like unsteady problem.
How could you model rolling maneuver as steady problem?
check this link, and start playing with unsteady problems...
Do you have manuals for sliding mesh problems? Be careful with interfaces!
I'M NOT A GYNECOLOGIST BUT I'LL TAKE A LOOK.
Centurion2011 is offline   Reply With Quote
Old   September 4, 2013, 07:07
duri
duri is on a distinguished road
Originally Posted by gfoam View Post
Hi everybody:
Gonzalo
Both approaches are correct. With MRF you can avoid interface errors and faster. There is no need use costly sliding mesh as your problem can be well represented with frame motion.
duri is offline   Reply With Quote
Old   September 4, 2013, 08:23
Gonzalo
Originally Posted by husker View Post
Regards
Yes, the maneuver is a steady one as the example of the bullet. And because the forward velocity an angular velocity are constant, I think the problem is a steady one.
As I said before the forward and angular velocity are constant, so I think the problem is a steady one, and I actualy want to avoid using the sliding mesh approach as far as possible.
Do you have any paper or publication where it is explained with some detail?
Thank you all for your answers.
Old   September 5, 2013, 01:55
Please pardon me, but I'm still in doubt that you would like simulate steady roll action. Roll action is a time-dependent maneuver, lets say the aircraft completes its rolling in a 20 seconds. In this manner, transient solver will let you see what would happen in that 20 second.
On the other hand, you can also simulate the rolling steadily. In that approach, you can use MRF and as duri offered, less computational resources are required by MRF rather than dynamic mesh. Practically you don't need an academic paper on how to apply MRF, instead, you can have a look at MRF tutorials such as pumps and turbines. Fluent has 2D fan tutorial.
Regards
Old   September 5, 2013, 09:03
Gonzalo
OK, I will try MRF formulation and I will see what are the results. Thank you all for the responses
Simulating aircraft at High Altitude UAV FLUENT 4 July 5, 2012 07:39
[ICEM] Annoying mesh holes on an aircraft Santos-Dumont ANSYS Meshing & Geometry 2 March 2, 2012 08:13
[CFD-Post] Calculating aircraft moments siw CFX 0 February 28, 2011 06:32
Aircraft in roll manouver Luca FLUENT 9 October 13, 2006 04:58
Aircraft Mesh Recommendation Sami FLUENT 2 April 2, 2006 13:23
