average velocity
Like Tree2Likes
  • 2 Post By like.no.other
Old   September 12, 2013, 03:30
Default average velocity
Sa.Baraty
sara22 is on a distinguished road
hello
I simulate one pipe that fluid flow in. after solve i want to calculate average pressure, temp and velocity at outlet of pipe.How i can calculate these parameters? In fluent i use 'Plot' or 'contour' option.
thanks
sara22 is offline   Reply With Quote
Old   September 14, 2013, 11:04
like.no.other
like.no.other is on a distinguished road
Originally Posted by sara22 View Post
hello
Hi Sara
go this way
report> surface integral> Area-Weighted Average(Report Type)
then you must select field variable and outlet (in surfaces) and finally click compute
enjoy!
nadernaderi and niazgdc like this.
www.CFDiran.ir
like.no.other is offline   Reply With Quote
Monitoring Volume Average of Liquid Velocity Magnitude in a Bubble Column / Airlift kevinlipps OpenFOAM Post-Processing 4 May 19, 2016 05:59
average velocity kato FLUENT 0 February 12, 2013 04:40
How to plot average velocity vs direction vector in fluent hamidhamidhamidhamidhamid FLUENT 0 January 1, 2013 14:13
Problem with time average tangential velocity in swirl flow. lakhi FLUENT 5 July 18, 2012 16:28
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 05:13
