Different strategy of convergence, different solution |
October 4, 2013, 16:34 |
Hi!
I simulating a transonic wing with airplane body and air inlet behind the wing . I use pressure far filed, pressure outlet for the limits of the domains and a pressure outlet with target mass flow rate for the inlet. Density based with Rke. If i achieve the convergence starting from the first order and at the end the second order I obtain ad solution that's different from the ones that i achieve starting the solution from a lower incidence solution with the second order active from the start. Anyone has the same problem (in terms of discrepancies of the solution)? |
How to find a good time scale strategy? | StefanG | CFX | 19 | June 8, 2012 08:41 |
Solution convergence problem - poor mesh? | Shawn_A | OpenFOAM Running, Solving & CFD | 2 | November 12, 2011 19:31 |
Force can not converge | colopolo | CFX | 13 | October 4, 2011 22:03 |
solution convergence problem | anbuselvan | FLUENT | 1 | January 18, 2009 04:00 |
[HELP]mixing plane convergence strategy?? | Pak | FLUENT | 0 | October 23, 2001 01:22 |
