Solid Region - Solid - Fluid conduction
Like Tree2Likes
  • 2 Post By longbk
Old   October 24, 2013, 04:41
Post Solid Region - Solid - Fluid conduction
Gilberto Santo
MrDaimon is on a distinguished road
I am trying to simulate (using Fluent 12.1) a flow of hot oil flowing in a steel pipe surrounded by a solid material (just like a heat pipe). As the oil flows it warms up the solid material. Now I ask you: how can I define the solid region surrounding the pipe? How can I make Fluent simulate that solid correctly? I hope my question was clear. I wait for your answers!
MrDaimon is offline   Reply With Quote
Old   October 24, 2013, 04:53
Long Nguyen
longbk is on a distinguished road
Originally Posted by MrDaimon View Post
In my opinion, you should divide your model into 2 zones: fluid and solid. For the interfaces between these zones, you should set them as interface in boundary condition. Then, create coupled wall for these interfaces in Mesh interfaces control. After that, back into B.C and set appropriate thermal value for these intefaces.
Good luck,
Long Nguyen
vigii and MrDaimon like this.
longbk is offline   Reply With Quote
Old   October 24, 2013, 04:59
Gilberto Santo
Thank you so much. Can you explain me how can I divide my model into two different regions? Do I have to do that during the meshing phase? I used Gambit for the generation of the geometry.
Thanks again!
Old   October 24, 2013, 05:11
Gilberto Santo
Thanks again!
Old   October 24, 2013, 05:20
Default Thanks
Gilberto Santo
I want you to know that I'm trying to simulate the flux usign a 2D domain, corrisponding to a half of the section of this pipe. I used Gambit for generating the mesh. Now I ask you: do I need a multibody tool during the mesh generation? Do I have to activate multiphase model during the simulation? Thank you so much!
Old   October 24, 2013, 11:20
Long Nguyen
Thanks again!
Dear Daimon,
You can divide your model into solid and fluid regions when you create your geometric model. I usually use Design Modeler for geometry generation.
BRs,
Long Nguyen
Old   October 24, 2013, 11:23
Long Nguyen
I think that activating multiphase model depends on what type of your fluid.
BRs,
Long Nguyen
fluent, heat pipe, solid fluid interaction
chtMultiRegionSimpleFoam samiam1000 OpenFOAM Running, Solving & CFD 39 March 31, 2016 08:43
Re-meshing a deformable solid body in a fluid brashear CFX 6 December 12, 2011 11:13
solid to fluid heattransfer with chtMultiRegionFoam nakor OpenFOAM 11 March 21, 2011 08:28
Extracting fluid flow region from a solid body 3D Pradeep Main CFD Forum 6 January 29, 2009 11:13
Modeling of solid domains in fluent, no fluid flow Satish Perivilli FLUENT 2 December 1, 2005 11:41
