Why y+=1 is required for Heat Transfer predictions?
Old   October 29, 2013, 19:06
Question Why y+=1 is required for Heat Transfer predictions?
motorbean
motorbean is on a distinguished road
Dear All!
I'm using k-omega-SST turbulence model in Fluent to simulate conjugate heat transfer on a blade surface. And I want to AVOID the wall-functions approach
I've read quite a few posts in which it is said that y+<=1 is required for heat transfer predictions.
My questions is, since the upper bound of the laminar sublayer of a turbulent boundary layer is y+=5, (and in this laminar sublayer, the velocity profile varies linearly in the wall normal direction, am I right?), then why not simply go for y+<=5, instead of requiring y+<=1?
I haven't found any detail explanation about why y+<=1 is required for Heat Transfer Predictions. Can someone tell me, or give me any links/documents for detail explanations, please?
Thanks, so much!!
motorbean is offline   Reply With Quote
Old   October 30, 2013, 02:40
Bionico's Avatar
Flavio
Bionico is on a distinguished road
Hi Motorbean,
k-omega SST required y+=1 in the boundary layer. I know that it's difficult to reach this target, so I think that y+<5 is anyway a good situation.
k-omega SST uses Enhanced wall function, so you should carefully avoid y+>10.
In conclusion the more you are near y=1, the more accurate the simulation will be.
Sorry for my bad english
Regards
Bionico
Bionico is offline   Reply With Quote
Old   October 30, 2013, 04:26
motorbean
Hi, Bionico, could you tell me why k-omega-SST requires y+=1? or do you some references about this?
I often see some people stressed that for heat transfer y+ should be <1, I would very much like to know the explanation behind this.
Old   October 30, 2013, 05:13
Bionico's Avatar
Flavio
Fluent R14.5 - Theory Guide (Chapter 4.4.4 - Wall Boundary Condition for k-omega):
"The wall boundary conditions for the k equation in the k-omega models are treated in the same way as the k equation is treated when enhanced wall treatments are used with the k-epsilon models"
So, considering that Enhanced wall treatment needs a value for y+ next to 1, you should refine your mesh as much as possible.
This requirement is important even for turbulence, not just heat transfer (anyway there's an interaction between them...)
Hope to be helpful
Best regards
Bionico
Old   October 30, 2013, 05:43
motorbean
Thanks Bionico. But do you know why Enhance Wall Treatment requires y+=1, rather than just y+<=5 ? Because I think,.. for y+<=5, the velocity variation is linear in wall normal direction, so what's the difference between y+=1 and y+=5?
Regards,
Motorbean
Old   October 31, 2013, 03:29
Bionico's Avatar
Flavio
Because Enhanced Wall Treatment equations resolve the viscous sublayer of the Boundary Layer, where the non-dimensional distance (y+) is <1.
y+<5 is anyway a good mesh but not optimal!
If you want to use a Standard wall function you can handle mesh with 30<y+<300.
Be careful to avoid y+ = 10-15 because there's the transition between the linear and logarithmic behaviour of the boundary layer!
See Fluent Theory Guide for more detailed (and graphical) information.
Regards
Bionico
Old   November 5, 2013, 17:33
motorbean
Thanks. The last thing to mention: it seems that the range for viscous sublayer is normally considered as y+<5, rather than y+<1, right?
Regards
Old   November 6, 2013, 02:06
Bionico's Avatar
Flavio
Yes, you're right: I've read back the theory and the range for viscous sublayer is y+<5.
Anyway if you use EWT, remember to go near 1 as much as possible.
Regards
Bionico
heat transfer modelling, y plus
problems after decomposing for running alessio.nz OpenFOAM 7 March 5, 2021 04:49
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 07:00
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 10:23
