November 8, 2013, 10:31 |
heat transfert during a compression
Marie
Rep Power: 12 |
I am running a simulation concerning a 2D adiabatic compression with the in-cylinder option. My simulation is running, my mesh is moving as I wish; The result concerning the velocity and the pressure are logical (see pictures). However the answer concerning pressure and temperature are false. In fact the temperature and the density stay constant during all the simulation, just as if there were no compression. I have chosen these parameters: - Piston as rigid solid - The two deforming walls (wall on the top and the down) as deforming - The end of the piston as stationary To take into account the temperature evolution of my fluid (air), I have activated the option energy equation. The piston and all the wall are adiabatics (I have chosen heat transfert=0) Velocity and size at t=o : size 14mm, constant velocity =0, see attached picture Velocity and size at t=0,01s, size 9mm, variable velocity, see the 2nd attached picture Do you have any idea concerning my problem ? Thanks |
November 11, 2013, 02:11 |
Marie
Rep Power: 12 |
any ideas ?
November 11, 2013, 09:05 |
Marie
Rep Power: 12 |
I have found the solution.
The density of my fluid was not taken as a ideal fluid |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Modelling the heat transfer during compression and cooling of natural gas | pano | Main CFD Forum | 0 | December 10, 2010 15:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
