Problem with modelling heat exchanger(fluid-solid-fluid-solid) |
December 11, 2013, 16:36 |
saman poura
Rep Power: 12 |
hi all
I am trying to model a simple heat exchanger,I want to see the temperature change between the two fluids and across the wall. I create the geometry and mesh with the gambit,and Analys it with fluent,but flow temperetures,not changes, T(inlet,cold water)=T(outlet,cold water) T(inlet,hot water)=T(outlet,hot water) i think my problem is boundery condition. I upload gambit files I hoped that some people on this forum would be able to help with a few issues I am having please help me thanks http://www.4shared.com/file/PTHRtFi2/g-f.html (dbs format) http://www.4shared.com/file/QZ2PFaij/g-f.html (mesh file) Last edited by samanpoura; December 12, 2013 at 03:36. |
fluid-solid-fluid-solid, heat exchanger model, two-sided wall, wall thickness |
Modeling heat transfer fluid to solid | Elvis1991 | FLUENT | 6 | December 7, 2012 09:08 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
goddamnit: how to set up heat transfer from fluid to solid | macfly | FLUENT | 7 | June 16, 2012 11:50 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Conjugate Heat Transfer between fluid and solid | Li Yang | Main CFD Forum | 8 | March 27, 2004 11:05 |
