Help: 2D Simulation of artery bifurcation, divergence error
Prev Previous Post   Next Post Next
Old   December 22, 2013, 11:51
Exclamation Help: 2D Simulation of artery bifurcation, divergence error
Spiros is on a distinguished road
Hello and thanks for reading this!
I have a project which ask me to simulate the flow in an artery bifurcation (one inlet-two outlets). I have done the 2D mesh using ICEM and now i want to calculate the flow of blood throw this artery.
The problem is that the minute i begin the calculation i get an instant error "Divergence detected in AMG solver: x-momentum".
I'm new in Fluent so i have no experience and i cannot , find the cause of this error. I try changing the URF but no matter what value i choose i get the same error instantly.
The conditions i'm sing are:
Wall:Non-slip, Stationary.
Inlet: Velocity Inlet (Method:Magnitude, Normal to Boundary, Vel.Magnitude=1 constant)
OUTLET_1: Pressure-outlet (Gauge Pressure=0)
OUTLET_2: Pressure-outlet (Gauge Pressure=0)
BODY: Blood (Density:1067, Viscosity:0.004)
Then i just change the Solution Initialization to Standard and Compute From Inlet and i press calculate for 200 iterations with time-step 0.01.
This is the same procedure we did in the lab for a normal 2d pipe flow with one inlet and one outlet.
Can you please enlighten on how i should do my simulation. What parameters i have to change or where the mistake might be.
If you want i can also upload the mesh.
Link to the image of the mesh (https://www.dropbox.com/s/mnis1gm09h...ifurcation.PNG)
I hope that you can help me with this. Thank you anyway for reading my question.
Spiros is offline   Reply With Quote
divergence detected, error, fluent
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 05:34
[swak4Foam] installing funkySetFields igo OpenFOAM Community Contributions 1 November 20, 2012 20:16
Ansys Fluent 13.0 UDF compilation problem in Window XP (32 bit) Yogini Fluent UDF and Scheme Programming 7 October 3, 2012 07:24
[swak4Foam] groovyBC: problems compiling: "flex: not found" and "undefined reference to ..." sega OpenFOAM Community Contributions 12 February 17, 2010 09:30
Compiling problems with hello worldC fw407 OpenFOAM Installation 21 January 6, 2008 17:38
