How do particle surface reactions work?
Old   January 2, 2014, 18:30
Default How do particle surface reactions work?
Sebastian
sebastian1430 is on a distinguished road
I've been reading a lot about DPM and particle surface reactions, but I can't figure out how does the reaction rate in Kg/s is used to report a reaction rate in Kgmol/m^3 s in the contours. I mean, in the UDF (DEFINE_PR_RATE) I impose a reaction rate of 1e-5 Kg/s, and then I'm sure fluent does something else with that reaction rate and the particles mass don't decrease 1e-5 Kg/s, and as I have different reactions, if I input the same rate, as example 1e-5 Kg/s, some rates are reported different in the contours. If someone understands how this works, please explain me. Thank you so much for your answer.
sebastian1430 is offline   Reply With Quote
define_pr_rate, dpm, fluent - udf, particle surface reaction, reactions
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 11:12
injection problem Mark New FLUENT 0 August 4, 2013 01:30
Particle Surface Reaction NunoLFC FLUENT 0 June 22, 2011 10:52
[ICEM] Automatic mesh generation script surface intersection problem stuart23 ANSYS Meshing & Geometry 0 May 13, 2011 01:10
Both volumetric and surface reactions Leverkin FLUENT 2 July 15, 2009 17:07
