January 9, 2014, 11:51 |
Modeling of underdrain Perforated pipe
Tanjina Afrin
Hello everyone.
I have modeled a perforated pipe surrounded by gravel . Pipe is full of water and gravel is submerged by water. Since the model was symmetry, I made it using Symmetry BC. ( Please see the attached image). I drew some hole in pipe and assigned the pipe surface as wall (in image 2 blue highlighted). So the hole acts as interior. I assigned the gravel zone as porous zone and put necessary parameter. What I am worried about that I didn't put any parameter for pipe hole. I read the fluent manual about perforated plate. I thought since the water would see the interior just after passing the pipe wall, it would act as real hole and would calculate the loss and other phenomena automatically . After simulation, I got result with 10-21 error with experimental result. So I assume I did something wrong with pipe hole. Could anyone please assure me if I have to assign porous jump boundary/any type BC to hole or fluent will understand automatically that its hole and will calculate the entrance and other loss on the hole? It will be a great help. Thanks in advance. Regards, Tanjina |
April 16, 2015, 15:30 |
Gonzalo
Hi, I know it's an old thread but if you coul help me I'll appreciate it very much. I'm about to carry out a similar simulation as you did (or attempted to do) and I'm confused about the boundary condition to set also in the pipe holes. Also I saw in another therad you started that you mentioned a paper which contains experimental results for this experiment, could you please let me know the title of that paper. Because the experimental data I found is about water-pipes with holes but without the porous media interaction. Regards
Gonzalo |
gravel, perforated pipe, porous jump, underdrain |
Modeling of perforated plate for 3 phase fluidized | Sanyo | FLUENT | 5 | March 27, 2015 11:01 |
[DesignModeler] pipe geometry variation modeling | timi-kun | ANSYS Meshing & Geometry | 0 | June 26, 2012 05:21 |
flow in perforated pipe distributor | pertupd | ANSYS | 0 | August 12, 2009 08:36 |
Modeling thin perforated plates as porous media | Mike | FLUENT | 0 | August 21, 2007 04:16 |
