gambit meshing question
Old   January 21, 2014, 15:43
Default gambit meshing question
futureamour is on a distinguished road
I am trying to simulate the two phase flow at a turbine nozzle(water-air) and I have done the geometry(in the bmp file below).
I have some problems with the meshing of it because of the irregular shape of the nozzle.I want a more dense mesh across the two walls,to capture the boundary layer and I cannot figure out how to do it.
I would like a structured mesh,so it is easy to configure it later (make it coarser and finer, and also move a bit the nozzle to the right,to simulate a different operation point of the machine).
The 'face' at the left is for the water and the right one for the air.
Should I make 2 virtual faces to enable the implementation of the 2 phase mixture?
Thanks in advance
futureamour is offline   Reply With Quote
[GAMBIT] 3D boundary layer and meshing problem in GAMBIT 2.4.6 prashanthreddyh ANSYS Meshing & Geometry 1 December 20, 2011 00:35
Gambit meshing error jx FLUENT 11 May 26, 2009 10:35
meshing difficulties in gambit jyothish FLUENT 6 June 7, 2004 04:13
Gambit - meshing question Pei-Ying Hsieh FLUENT 1 November 26, 2001 10:08
GAMBIT meshing problem Gauthier Lambert Main CFD Forum 1 August 3, 2000 09:22
