How to keep the water level constant at inlet
Old   August 13, 2013, 10:45
Default How to keep the water level constant at inlet
Tanjina Afrin
Tanjina is on a distinguished road
Hello all,
For keeping the water height constant at inlet, which BC should I use when I don't know the mass flow rate ( for mass flow rate inlet) and velocity ( velocity inlet) ? I used pressure inlet, but from static pressure contour , I found negative pressure at inlet portion. I am using multiphase ( VOF) model .
It will be great help if anyone can suggest me anything. Thanks in advance.
Tanjina is offline   Reply With Quote
Old   August 14, 2013, 07:53
Stephan Langenberg
Jim87 is on a distinguished road
You want to establish a constant water level? I think you have to possibilities (based on your model and settings).
The easy one is working with profiles for the inlet (non constant velocity and non constant mass inlet). -> If you can calculate your massflow.
The other way is using UDF for your inlet. You may set a pointer for (pressure, velocity, VolumeFraction) on a Cellzone or face and regulate your inlet velocity by it.
I imagine something like a sensor for the volume fraction. If the Volume fraction in one cell is higher than X (because of raising water level) the pointer activates a clipping function in the inlet and reduces or stopps the velocity inlet.
What I don't know without using the manual is how to point pressure or an other value in a seperate cellzone, but I've read it ones.
Jim87 is offline   Reply With Quote
Old   August 14, 2013, 11:15
Tanjina Afrin
Hi Jim,
Thank you very much for your reply. you know any way that I can calculate mass flow rate ? I am working with 2D and 3D both.
Unfortunately, I couldn't understand your UDF part. can you explain a little bit ?
Thanks in advance.
Old   August 14, 2013, 11:52
Stephan Langenberg
I don't know your model, so I can't say if you can calculate your needed mass flow inlet. If it is a easy model you can calculate with analytic and use fluid mechanics...
The UDF is a function written to adapt the flow inlet to a a criteria you choose.
In an experiment you could set an sensor in a position X, when the water level arrives the sensor he would give a signal and regulate the inlet.
An UDF has the possibility to do the same in your numeric system. The sensor could be a pointer and activate a function (maybe stop velocity inlet) if a physical value (temperatur, volume fraction etc.) reachs a special magnitude.
Hope my Position is clearer now.
Old   August 14, 2013, 12:20
Tanjina Afrin
HI JIm,
Thank you very much . My model contains two part. One is filled with gravel and water will pass through this porous zone to a pipe. I want to keep water height constant at this porous region. I don't have any discharge or velocity data. So is it possible to calculate mass flow rate here?
And about UDF, now I am reading UDF manual fluent. Hopefully, after reading some example , I will be little bit familiar with it.
Thanks for your generous help.
Old   August 14, 2013, 13:33
John is on a distinguished road
Originally Posted by Tanjina View Post
Hello all,
To set a constant height at inlet area, you may try to split the domain to two. set the volume fraction of the sub-domain which includes inlet BC as fixed value (=1).
But first you have to make sure that such a setting is physically correct.
John is offline   Reply With Quote
Old   August 19, 2013, 22:12
Tanjina Afrin
Hi John, I am sorry that I just missed the notification that someone has answered my query. I am not sure how to split the domain to two, but as a normal VOF model, Inlet had three phase, one is water, one is air and third one is mixture. I allowed to water volume fraction =1. From the volume fraction of water contour shows that water level is constant, but from static pressure contour I found that there are negative pressure just below the inlet with a magnitude of -84 pascal. So I got worried. Do you have any idea about that ?
Old   August 30, 2013, 07:41
vig
anonymous
vig is on a distinguished road
Have you used specified operating density option with the density of lighter phase.
vig is offline   Reply With Quote
Old   August 30, 2013, 09:49
Tanjina Afrin
Yup, I did.
My problem is somehow solved now..... what I did wrong there is I plotted the contour with static pressure. After plotting the total pressure, pressure is zero at inlet, which means that water level remains constant.
Old   January 21, 2016, 10:18
Alireza Bahmanpour
alirezab is on a distinguished road
Hi Tanjina,
Could you please clarify more how you solved your problem? I also need to set my inlet flow level to be constant.
Thanks,
Ali
alirezab is offline   Reply With Quote
Old   January 21, 2016, 10:29
Tanjina Afrin
Hello AliRezab,
I had two type of settings. For one case, I had side inlet (water entered into the domain from side) and I needed to top water level of the domain be constant. For that case, I used symmetry boundary condition, which means I forced the domain's water surface to be constant. And for another case, I had top inlet (water entered into the domain from top) and again I needed top water level be constant. That case, I used pressure inlet with zero pressure. Reference pressure was atmospheric pressure.
Hope it helps.
Regards,
Tanjina
inlet bc, vof
Water subcooled boiling Attesz CFX 7 January 5, 2013 03:32
How to estimate water level in two phases channel flow? apollo11ho CFX 2 July 18, 2012 09:34
[swak4Foam] Trouble setting groovyBC interFoam Inlet BC mgdenno OpenFOAM Community Contributions 4 July 1, 2012 08:16
Constant gauge pressure inlet yan FLUENT 1 June 3, 2005 12:13
Patching of a constant value at inlet Chimwemwe Banda FLUENT 1 January 5, 2005 01:44
