January 27, 2014, 05:13 |
mass flow Inlet Guage pressure
Siddhardha Seetala
Rep Power: 13 |
I am trying to simulate flow through atomizing nozzle. Through which certain mass of pressurized air is passing for atomizing fuel.
For this should I put the value of 'Gauge pressure of atomizing air measured from a pressure transmitter' in Initial Gauge pressure field? Known values: mass flow rate = 0.1369 kg/s temperature = 313 K measured pressure = 9669950 Pa Please also explain, when exactly we should give this initial gauge pressure value. |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
Boudaries for bouynat driven flow with additional mass flux at inlet | Charon | CFX | 2 | April 27, 2013 08:02 |
UDF for transient pressure inlet, mass flow check at nozzle exit and volumetric heat | kokoory | FLUENT | 0 | August 17, 2011 02:07 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Mass flow inlet B.C. at exit... | Jack Keays | FLUENT | 2 | October 6, 2000 08:39 |
