How to get interpolated values of isosurface
Old   January 8, 2014, 12:08
Default How to get interpolated values of isosurface
Adam Læssøe
AdamAL is on a distinguished road
I have a solution with a wavy free surface (air/water interface - marine environment). Within Fluent i can create a nice looking isosurface of the interface (using volume-fraction = 0.5). It looks nice and sharp, so Fluent is clearly interpolating to get a more exact fit than simply "center of cell containing VOF-fraction<1".
However when I try to export the surface's data, (file>write>profile: [surfaces: isosurface, values: y-coord], I get some very jagged data - presumably corresponding to "center of cell cut by isosurface".
I suppose I could export the volume fraction in the entire domain and recreate an isosurface in another postprocessing tool, but that would A) duplicate a lot more data, and B) require redoing the work that Fluent has already done (fitting the isosurface).
Does someone here know of a better solution?
AdamAL is offline   Reply With Quote
Old   February 10, 2014, 16:53
Adam Læssøe
For the future googler. It turned out I was not completely right.
If you export profile with cell values, and choose y-coordinate as the parameter to export, then yes,
the parameter in the resulteing .prof-file will be the cell-coordinate-not the iso-surface coordinate.
However, Fluent also exports the x-, y- and z-coordinates of the surface itself.
I.e. you have to use those values instead. These fields are simply called 'x', 'y', 'z' (as opposed to 'y-coordinate').
dataexport, isosurface
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 06:55
Retrieving boundary patch values adjacent to a given cell brooksmoses OpenFOAM Post-Processing 2 December 8, 2008 10:00
Plotting raw data values Wilesco Siemens 0 January 5, 2006 05:34
Mass Flux values and calculations Cb Siemens 1 January 22, 2005 09:21
node based or cell centered Ts values acboge FLUENT 0 February 6, 2004 06:41
