Playback animation mesh
Old   February 11, 2014, 04:58
Default Playback animation mesh
Anna-Sofia
AnnaSofia is on a distinguished road
When using a dynamic mesh, is it possible to record the transient changes in the mesh?
Is it possible to save a picture of the mesh each time FLUENT remeshes?
AnnaSofia is offline   Reply With Quote
Old   February 12, 2014, 09:00
Francisco
Bollonga is on a distinguished road
Hi Anna Sofia,
You can define an animation at Calculation Activities/Solution Animation- Create/edit
You can choose how often (iterations or timesteps) you want to save a picture, and you can select the picture format, the camera viewpoint, the variable, etc. at Define.
You can animate all the frames later on in Graphics and Animations/Solution Animation Playback.
Hope this helps
Bollonga is offline   Reply With Quote
Old   February 13, 2014, 09:15
ghost82's Avatar
Rick
ghost82 will become famous soon enough
Or if you want to use third party softwares for post-processing, as tecplot for example, you have to save both cas files (in which you save each step of "the dynamic mesh") and dat files (in which you save solutions).
Then you will import cas and dat files and you can create mesh animation; without cas files your mesh will not move.
Daniele
ghost82 is offline   Reply With Quote
animation, dynamic mesh, playback
[snappyHexMesh] Add Mesh Layers doesnt work on the whole surface Kryo OpenFOAM Meshing & Mesh Conversion 13 February 17, 2022 07:34
[ICEM] surface mesh merging problem everest ANSYS Meshing & Geometry 44 April 14, 2016 06:41
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
basic of mesh refinement arya CFX 4 June 19, 2007 12:21
